Hi, Somebody help me please! Tried factory restore by F11 rescue and recovery but after restart with system option it doesn't show Lenovo rescue and recovery on the menu. What should I do? Please help me if you know. Windows 7 pro 64bit BIOS was updated. Thanks.
SOURCE: RESTORING FACTORY CONTENTS.
That is because someone has either removed, formatted or overwritten the partition on which the recovery software was stored. You'll need to find CDs of the software you want, starting with the OS, and install that way.
SOURCE: After Rescue n recovery with F11, i got error messeges & all data
probably not easiest way is get a cd and do a fresh install
If you need further help, reach me via phone at https://www.6ya.com/expert/david_eb7ea98642566cc6
SOURCE: Start up problem
try to log on safe mode if this not work u need to format ur laptop and install a new windows
SOURCE: Can't connect to the internet after running Rescue and Recovery
It seems you have a static ip address. Check the ipaddress by clicking - start -run - type cmd hit enter. on the black screen - type ipconfig and enter. If the ipaddress shows ipaddress e.g 169.10.14.12 . its is static ipadress. Do ipconfig /release then ipconfig /renew.If u are getting new ipaddress. Ping www.google.com and check if you are able to ping. You should be able to connect to internet. If not then reset the Internet router if you have one or shut down the computer.Disconnect internet cable .If u have modem,turn it off.Wait for 10 second. Connect internet cable.Restart the system and check. If issue persist contact ISP. Good luck.
SOURCE: My Lenovo ideapad z565 with Windows 7 does not
For you to perform One Key Recovery, it is done by pressing the OKR button next to power button when the computer is off..(OKR or One key recovery is a very small button usually next/ near the power button that has an inverted U-shaped arrow and usually, some models, the color is orange button)..Select "One key recovery" from the options and next, select "Restore from Initial Back up" after that, you may select "start" to perform OKR..
Just in case OKR button is no longer working, you may ask for the recovery CD's from lenovo to manually install windows.
If your Lenovo desktop is pre-installed with Windows operational system, press one-key reset key when your laptop is power off. Or press Shift + B to come back to factory setting instantly when Lenovo desktop is open.
Or press F2 when your Lenovo desktop is powering on. Few seconds later, a dialog pops up with several options, one-key reset and reset factory setting. Follow the operation wizard to reset factory setting is OK.
Related topic:
Power off the laptop. Remove any peripheral devices such as speakers, printers or flash drives that are not necessary to this operation. Connect your laptop to power/adapter.
Very Important: Please make sure you have backed up all important data because restoring your device to factory settings will result in loss of all data and software, Though all software that came preinstalled with the computer will come back.
1. Backup your important data in external hard-drive or flash drive.
2. Shut down the computer.
3. Turn the PC back on and hit the F8 key repeatedly until the Advanced Boot Option Screen appears.
4. Click "Repair Your Computer" if you are not already on it and then press ENTER
5. Choose your keyboard & language options and click OK
6. On the "System Recovery Options Screen" click "Complete PC restore" which is probably the second last option.
7. Follow the on-screen instructions
8. When prompted, click on "Full Factory Recovery"
9. Click "Next"
10. Click "Yes"
11. You may notice for a while it seems like nothing is happening, give it some time.
12. After some minutes, recovery will complete and you click "Finish".
13. Computer will restart and it will boot to desktop just fine. It might ask you to configure some settings as this is equivalent to starting a new computer.
Cheers.!!!
