Sewing Machines Logo
j
jack Posted on Mar 17, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How to thread a bobbin - Sewing Machines
Alphonesrani
Level 2:
Champion:
Habit-Forming:
  • Expert 201 Answers
  • Posted on Mar 18, 2014
Alphonesrani
Expert
Level 2:
Champion:
Habit-Forming:
Answers
201
Questions
0
Helped
38274
Points
329
Hai, New cotton thread or silk thread is best. Otherwise your choice.
Bobbin winding is very must and careful. Please see the link:
Ruffles And Stuff Getting Started Winding and Threading Your Bobbin
My bobbin wont pick up on me simplicity se3
Make sure the needle is not bent and fully inserted into the holder. Replace needle if in doubt.
Be sure the bobbin is properly loaded onto case.
Only use the bobbin designed specifically for this machine.
Be sure the bobbin thread is captured by the bobbin tension spring when you load bobbin into machine. Use your left hand to position bobbin thread per machine instructions. Press on the bobbin with right index finger to prevent the bobbin from turning as you position bobbin thread. Dont use the bobbin thread trimmer, yet.
With left hand put tension on the bobbin thread as you pull bobbin thread towards the trimmer. When the bobbin thread is in the tension spring you can release right index finger and you will feel the resistance of the bobbin tension spring. Now finish the bobbin thread per machine instructions and use the bobbin thread trimmer.
Babylock enterptise embroidery machine. bobbin thread stitches get pulled up to top of fabric. How do I adjust tension to fix this problem?
Bobbin thread showing on top side means the top thread tension is too high or there is too little or no bobbin thread tension.
Be sure the bobbin thread has not escaped the bobbin thread tension spring.
If the bobbin thread is in its tension spring, there will some resistance when you pull the bobbin thread.
Select top thread tension 2, lower presser foot and pull on top thread. Tension should be similar to bobbin thread.
Comment below for further assistance.
Threading bobbin on model #385.19106900
Do you need to wind a bobbin or place it in the bobbin case for sewing? For bobbin winding, make sure that the top thread is on the spool pin with the appropriate spool holder. Bring the thread under the first thread guide (going from right to left, as you face the front of the sewing machine). Bring the thread around the bobbin winding tension disc so that the thread is under the tension disc. The thread goes from left to right on the front of the disc. Bring the thread to the bobbin and put the thread goes through the hole in the bobbin (from the inside of the bobbin to the outside). Put the bobbin on the bobbin winder spindle and slide the assembly to the right. When the spindle is in the correct position, the needle bar will not move. Hold the free end of the thread above the bobbin and start the sewing machine. After the bobbin has a few layers of thread, stop the machine and cut the excess thread off at the top of the bobbin. Resume winding the bobbin until full (or as full as you need). The machine will automatically stop when the bobbin is full. Move the bobbin winder spindle to the left and cut the thread to separate the bobbin from the top thread. Remove the bobbin from the spindle and thread the top thread back through the guides to the needle.
To place the bobbin correctly in the machine, remove the hook cover plate if you have another bobbin in the machine. Push the release button to the right and then lift the cover up. Lift the previous bobbin out of the bobbin case. Put the new bobbin in with the thread coming off the bobbin counter-clockwise with the hole of the bobbin up. Bring the bobbin thread around the case and into the notch near the front of the bobbin case. Continue to pull the thread lightly around to the second notch. Leave about 6" of thread out past the second notch. Replace the hook cover plate.
Sears Parts Direct has the manual for the Kenmore 385.19106900 here: https://www.searspartsdirect.com/partsdirect/user-manuals/38519106900-kenmore-parts-manual . The direct link to the manual is https://c.searspartsdirect.com/mmh/pd_download/lis_pdf/OWNM/L0911547.pdf . See page 20 (page 32 of the PDF) for the images that go with the bobbin winding directions. See page 22 (page 34 of the PDF) for the bobbin threading directions and pictures of the notch locations.
I hope this helps.
My bobbin winder will not engage
1. Turn the power on the machine.
2. Open the bobbin winder cover at the top on the right side of the sewing machine.
3. Swing up the bobbin thread spool pin. Move the bobbin thread spool pin up as far as possible.
1-Bobbin thread spool pin
4. Place the bobbin on the bobbin winder shaft so that the spring on the shaft fits into the notch in the bobbin.
1-Notch
2-Bobbin winder shaft spring
5. Slide the bobbin winder shaft to the right.
NOTE: If the correct size bobbin is not used at this time; when the bobbin winder is engaged; the bobbin winder will make a usual noise and not wind the bobbin correctly.
6. Place the spool of thread for the bobbin onto the bobbin thread spool pin.
7. Slide the spool cap onto the bobbin thread spool pin.
NOTE: If using thread that winds off quickly, such as nylon or metallic thread, place the spool net over the spool before placing the spool of thread onto the spool pin.
8. Pull out some thread, and then thread the thread guide for the bobbin winding. Hold the thread with both hands, and then securely pass the thread as far as possible into the two slits in the thread guide.
1-Thread guide for bobbin winding
2-Two slits
9. While using your left hand to hold the end of the thread that wraps around the thread guide for bobbin winding, use your right hand to wind the free end of the thread clockwise around the bobbin five or six times.
10. Pull the thread to the right and pass it through the slit in the bobbin winder seat.
My bobbin thread breaks too much. How do I fix it.
Be sure you are using the correct bobbin for your machine. Even though it appears to fit the bobbin case, if it is the wrong bobbin, it could cause major headaches.
Try a different bobbin. Try different thread.
Also check that the bobbin thread is wound smoothly and turning the correct direction in the bobbin case. Make sure the thread is threaded through the bobbin tension properly.
AVOID old and inexpensive, bargain bin thread!
There could be a nick or burr somewhere that is catching the bobbin thread and breaking it.
Try loosening the bobbin tension a bit. It could be too tight, especially if the bobbin thread is pulling the upper thread down to the underside of the fabric.
There could also be something wrong with the bobbin case itself that may be resolved by trying a new bobbin case (or borrow one from a friend, etc.)
Dealing with Lower Thread Breaking Sewing
Bobbin Thread Breaking How to Loosen Bobbin Tension
1helpful
Thread a bobbin on a 5825c
If you mean the Singer 5285C, the manual is available from Singer here: http://www.singerco.com/uploads/download/449_5_6_8_10_slide.pdf . The diagram for winding the bobbin is on page 14 and inserting the bobbin is on page 15.
I'll attempt to walk through the steps. Push in on the indent on the hand wheel to lock the needle in the current position (note rotate the needle up first). Then with a spool on the spool pin and the cap securely holding the spool on the pin, snap the thread through the thread guide post (near the center back of the top of the machine). Then wind the thread clockwise through the bobbin tension guide (towards the center front of the top of the machine). Next run the thread through the hole in the bobbin (inside to outside). Place the bobbin on the bobbin spindle on the front of the machine near the right hand side of the machine. Hold onto the thread end at the bobbin and start pushing down of the foot controller. Fill the bobbin to the amount of thread that you need, or until it stops. Cut the thread going from the spool to the bobbin.. Remove the bobbin from the spindle and trim the thread end that is sticking through the hole in the bobbin. Press the hand wheel disc on the side opposite from the indent.
Inserting the bobbin requires you to lift the presser foot and have the needle in the highest position. Slide open the face plate and remove the empty or wrong color bobbin. With the hole in the bobbin up, pull about 4" of thread off the bobbin. Place the bobbin in the bobbin case and hold it down lightly with a finger. Guide the thread through the notch near the front of the bobbin case. Then lead the thread down into the slot on the left and then around the second notch. The thread should be heading towards the center of the bobbin (left to right). Pull the thread diagonally back to the back of the machine and slide the bobbin cover closed. The thread should be coming up through the opening between the cover and the needle faceplate. To pull up the bobbin thread, thread the needle and then hold onto this top thread. Rotate the hand-wheel towards you until the needle rises above the needle plate. Gently tug on the top thread to bring up the loop of thread. Separate the needle thread from the bobbin thread with your fingers. Bring the top thread through the left side opening in the presser foot and then pull both threads to the back of the machine.
I hope this helps.
3helpful
2answers
I have a faithful 730 Bernina and currently the bobbin thread keeps breaking. Please advise what may be causing this. Thanking you.
Bobbin thread breaks
1. There is a right way & wrong way to insert the bobbin in the case --when you insert the bobbin in if it doesn't stitch correctly turn the bobbin over see if that helps or bobbin case is not inserted correctly
2. Lint has collected in the bobbin holder
3. The bobbin is damaged & doesn't turn smoothly
4. Lower thread tension is two tight
here's a free manual
http://www.bernina.com/getdoc/48e8d09f-98f7-40ab-8663-a23663df4fae/Bernette_715_730_740E_manual
1helpful
2answers
The upper thread is too loose and the bobbin thread is taken up too much
It is the upper thread which pulls the bobbin thread up. If the bobbin thread is taken up to much, one solution is to loosen the upper thread -- but the upper thread is too loose. Therefore, the same problem needs to be combated from the bobbin side.
The thread from the bobbin should slide through a wedge. On that wedge should be a screw. It needs tightened. The bobbin thread should be tight as follows:
A fully loaded bobbin should tangle by the thread without falling. While dangling the bobbin by the thread, bounce the bobbin (yo-yo style). An easy tug should cause the bobbin to release an inch or two of thread and then the bobbin should stop falling on its own.
Once the bobbin tensioner is correct, you should be able to tighten the upper tensioner.
1helpful
I own a "Lena" machine
Hello
Make sure your feeddogs are up. That is the little jagged looking plate under the pressure foot. There should be a setting on your machine that will move it up and down.
If they are up then the bobbin is not in correctly. If it is a normal round bobbin that fits in a bobbin case, hold the bobbin in front of you so that the thread end is on top and the thread is going away from you, and slide it into the bobbin case. Feed the thread through the right openings in the bobbin case. When you pull the thread end the bobbin should turn clockwise.
Never hand-wind bobbins. Instead, use the accompanying bobbin winder which is attached to most machines,bobbin casings must be oiled regularly to prevent problems with the bobbin turning properly. The bobbin, when inserted properly into the bobbin casing, should spin counter-clockwise when thread is pulled.
Check the way your machine is threaded. Completely un-thread your sewing machine and re-thread it. Remember to always thread your machine with the presser foot up.
Check the bobbin and be sure the bobbin is threaded correctly and that the bobbin case is correctly threaded. Be sure the bobbin is in the bobbin case in the correct direction.
Always watch for bobbin wear, especially on the plastic type of bobbins. If the edges of the plastic are showing abrasions, the size of the bobbin has changed and may be the culprit. Although the size change is minute, it allows the bobbin to wobble in the case and changes the tension.
3helpful
How do you load the bobbin properly?
Well you may please follow the steps below -
1. Remove the bobbin from the sewing machine. Note: whether you have a drop-in, front or side-loading bobbin on your sewing machine. A drop in bobbin will load from the top, may be via a removable bobbin case cover near the machine-fed dogs. A side or front loading bobbin needs to be loaded into a removable bobbin case under the machine.
2. Choose the right size bobbin for the sewing machine.
3. Wind thread onto your bobbin. Your sewing machine should have a standard thread spool to hold the thread and a short, squat post wide enough for a bobbin.
4. Put the thread and empty bobbin into position on your sewing machine. Wrap the thread around the bobbin to start it. On most machines, disengage the needle by turning the smaller hand-wheel on the machine toward you. Push the bobbin post into position, securing the bobbin into place. Press gently down. Thread should begin to wind neatly onto your bobbin.
5. Break the thread, push the bobbin post back into an inactive position and remove the bobbin. Tighten the hand-wheel. Thread your sewing machine again if necessary before loading the bobbin.
6. Remove the bobbin case cover and put the bobbin into position. The thread should slide through a catch on the bobbin case and up through the cover.
7. Access the bobbin case for a front or side mount bobbin. Lift the catch and remove the removable bobbin holder. Put the bobbin into the holder and run the thread through the holder, bringing it to the front. Lift the catch and slide the bobbin holder back into the case. Hold your needle thread gently forward with your left hand and turn the hand-wheel. The needle thread will pass down into the machine and catch a loop of the bobbin thread. Pull this loop up and slide both threads to the back before beginning to sew.
Good Luck!!
Thanks for using FixYa!!
Top Sewing Machines Experts
SmartAviator
SmartAviator
Are you a Sewing Machine Expert? Answer questions, earn points and help others
