Toyota Navigation Genuine SD NSDN-W59 Logo
j
jayrajlobine Posted on Mar 09, 2014
Can i connect a usb device?
I want to connect a usb device,can i do that?
I connected a USB stick to The USB port in my LG 42LH2000 but I can't get it to work, there's no USB options on input. Can someone please help
How can i play videos from a USB with a Kenwood DDX715WBT i tried MPEG-2, WMV, DIVX, AVI, but it doesnt play it shows Unsupported File.
These excerpts from the user's manual....
USB
Connecting a USB device
You can connect a USB mass storage class device
such as a USB memory, Digital Audio Player etc. to
the unit.
• For details about connecting USB devices, see
page 70 .
• You cannot connect a computer or portable HDD
to the USB input terminal.
• For playable file types and notes on using USB
devices, see page 75.
When a USB device is connected...
The source changes to
"USB"
and playback starts.
• All tracks in the USB device will be played
repeatedly until you change the source.
[PAGE 75]
USB playback
Playable files on a USB device
• This unit can play the following types of files
stored in a USB mass storage class device.
- JPEG/BMP/PNG/MPEG1/MPEG2/MP3/WMA/
WAV/AAC/FLAC/H.264/WMV (VC-1)
• This unit can recognize a total of 5 000 files and
250 folders (a maximum of 999 files per folder).
• Make sure all important data has been backed up
to avoid losing the data.
Notes on using a USB device:
• This unit may not play back files in a USB device
properly when using a USB extension cable.
• USB devices equipped with special functions such
as data security functions cannot be used with the
unit.
• Do not use a USB device with 2 or more partitions.
• Depending on the shape of the USB devices and
connection ports, some USB devices may not be
attached properly or the connection might be
loose.
• This unit may not recognize a memory card
inserted into the USB card reader.
• When connecting with a USB cable, use the USB
2.0 cable.
The maximum number of characters (when the characters are 1 byte):
- Folder names: 128 characters
- File names: 128 characters
• Avoid using the USB device if it might affect
driving safety.
• Do not pull out and connect the USB device
repeatedly while "Reading" is shown on the
screen.
• Electrostatic shock at connecting a USB device
may cause abnormal playback of the device. In this
case, disconnect the USB device then reset this
unit and the USB device.
• Operation and power supply may not work as
intended for some USB devices.
• Do not leave a USB device in the car, or expose to
direct sunlight or high temperatures to prevent
deformation or damage to the device
I have a JVC KD-AHD79 stereo. I tried plugging my Samsung Fascinate phone into the USB port to use the music on the memory card but it either says "cannot play" or gets stuck on...
This unit is able to take I Pod and I Phone. If unable to connect your particular phone/device via bluetooth please note the following?
• Make sure all important data has been backed up. • You cannot connect a computer or portable HDD to the USB input terminal of the unit. • Avoid using the USB device if it might hinder your safety driving. • Electrostatic shock at connecting a USB device may cause abnormal playback of the device. In this case, disconnect the USB device then reset this unit and the USB device. • Do not leave a USB device in the car, expose to direct sunlight, or high temperature to avoid deformation or cause damages to the device. • This unit may not play back files in a USB device properly when using a USB extension cord. • USB devices equipped with special functions such as data security functions cannot be used with the unit. • When connecting a USB cable, use the USB 2.0 cable. • Do not use a USB device with 2 or more partitions. • Depending on the shape of the USB devices and connection ports, some USB devices may not be attached properly or the connection might be loose. • This unit cannot recognize a USB device whose rating is other than 5 V and exceeds 500 mA. • Do not pull out and attach the USB device repeatedly while "READING" is shown on the display. • This unit may not recognize a memory card inserted into the USB card reader. • Connect only one USB device to the unit at a time. Do not use a USB hub. • Operation and power supply may not work as intended for some USB devices. • The maximum number of characters for: - Folder names : 63 characters - File names : 63 characters - MP3 Tag : 60 characters - WMA Tag : 60 characters • This unit can recognize a total of 65 025 files, 255 folders (255 files per folder including folder without unsupported files), and of 8 hierarchies.
Good luck with it.
When I connect to my computer it gives me a message saying device not recognized
Merry Christmas!!!
Greetings for the festive seasons!
It seems like you are connecting a USB device to our computer. USB is a PNP bus. whenever you connect anything to USB, some handshaking is done by the OS with your USB device, so as to recognise its class (if it is a storage device or printer etc,) and other details like its manufacturer, capacity etc. If, for any reasons, this handshaking is not done, this error is raised.
to solve this problem, try following things
1. change cord and try again.
2. If it is a USB hard disk, try twin USB cable. where single USB end is connected to the USB hard disk, and twin USB side (both the pins) are connected to the. PC. It happens, when device is consuming more power, so some additional power is needed to drive it.
3. If it is a mobile, printer or camera, install drivers first and then connect the device.
4. If you are connecting it to front USB ports and the wiring inside is made incorrct. This nmay cause damage to any device you connect to that port. if any other product is working on that port, then simply rule out this probability
5.Try different port, as the device you are using may be using higher version (USB 2.0 or USB 3.0). but this is rare case, as PC itself will prompt you by "This device can work faster"
6. Device itself is faulty. try connecting, similar device to your PC and confirm.
If it is not solved, give brief description of what are you connecting to your PC and what have you tried before.
1helpful
USB taking too long to transfer vista
Note that USB ports (in your computer) and USB devices can either be "USB 1" or "USB 2" speeds.
While "USB 2" to "USB 2" connections are up to 480 Mbits/second,
any "USB 1" to "USB 2", or "USB 1" to "USB 1", connections,
will max-out at only 11 Mbits/second.
So, check that you have a "USB 2" device.
then check that you are connecting to a "USB 2" port on your computer.
Give more details about your computer, and your USB device.
My computer cannot detect usb my computer model is 6bxa-61 samsung
You were saying that your computer could not detect any USB devices? Or just one USB device? Alright, you need to isolate the problem, follow the steps below:
1. Use at least 3 USB devices and connect them one at a time to the USB ports of your computer. If the first USB device is not detected, mark the USB port on your computer with "X" mark.
2. Now, connect the same USB device to another USB port of the computer. If you get the same problem, use the second USB device and connect it to the computer. If all 3 USB devices are getting the same problem connecting in all the USB ports of the computer (either on the front or on the back of the computer), then you need to update or re-install the USB driver to your computer.
3. Contact the manufacturer if the computer or the board and see if they could provide a USB driver for *********** board. Tell them what operating system (OS) you are currently running.
Have a great day!
Computer not recognizing usb connected nav device
Turn off CPU, Unplug Power cable, And all usb devices, let it sit for about 20mins. Plug it all back in. Turn on the CPU! Also make sure if your device requires "DRIVERS" or if you have a CD download and install that before anything.
I have no idea how it happened, but i plugged it into my computer to charge. and then i just saw my mp3 player and the screen froze and it says usb connecting and when i plugged it out it still said usb...
  1. Connect the USB cable to your computer.
  2. Press and hold the menu[0].jpg button while plugging the other end of the USB cable into the YP-Z5.
  3. When the display shows USB Connected, release the menu[0].jpg button.
  4. The device is now in USB mode.
  5. When through, you must safely remove the USB device. Note: To safely remove the USB device, right click the USB icon ( usb_icon.jpg ) in the bottom right of your screen, and then click Safely Remove Hardware.
  1. Upon disconnecting the device, it will return to MTP Mode.
Music software of Samsung YH-925 20 GB MP3 can't regcognized the device
You may get the error that you're getting if there's a problem with the USB port of the computer, with the USB cable, or with the USB port of the device itself.
Try connecting the Samsung mp3 device to a different USB port of your computer. Usually, it's best to connect the device on the USB port at the back of the computer. Make sure that the USB cable is properly inserted on the USB port of the device and on the computer.
You may also try connecting the Samsung mp3 device to a different computer to isolate the problem.
Another isolation is to try connecting a different USB device on the computer, just to check if the USB ports of the computer is working properly.
Try using a different USB cable also, if you have any.
For more help: http://www.supportrix.com
Top Toyota Toys Experts
Thomas Perkins
Thomas Perkins
Stan Ford
ADMIN Eric
ADMIN Eric
Are you a Toyota Toy Expert? Answer questions, earn points and help others
