Computers & Internet Logo
Posted on Mar 06, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
FIXYA The power supply output of my Dell Dimension 8200 desktop pc is delayed for minutes after i press the ON button in the tower front. The momentary button switch is OK. The delay is 15 minutes if
FIXYA The power supply output of my Dell Dimension 8200 desktop pc is delayed for minutes after i press the ON button in the tower front. The momentary button switch is OK. The delay is 15 minutes if the computer has been idle for a few hours, but is only a few seconds if the button is pushed shortly after XP shuts the computer off. Fearing that some unknown cause will completely prevent a power-on, I have been keeping it on 24/7. Does anyone know how to fix it, or where I can look for a fix? I posted this weeks ago, suspecting a bad switch, before recognizing the delay.
PC Servis Kod Fontane BGD
Level 2:
Habit-Forming:
New Friend:
  • Expert 130 Answers
  • Posted on Apr 22, 2014
Expert
Level 2:
Habit-Forming:
New Friend:
Answers
130
Questions
Helped
16776
Points
173
It's not about the switch, a problem may be caused by bad power management control driven by XP. Ask on DELL's forum about any patches about this. Finally, check-up your power management scheme.
PC Servis Kompjutera Kod FONTANE Popravka Odrzavanje Laptop Racunara
5 Related Answers
Anonymous
  • 49 Answers
  • Posted on May 31, 2008
SOURCE: Replacement Video Card - Dell 8200 w/ NV25
I have a couple of graphics cards that will do the trick. Email me back and I will help you out.
Anonymous
  • 6 Answers
  • Posted on Sep 23, 2008
SOURCE: Dell Dimension 2400 won't turn on
replace the fuse
Anonymous
  • 17 Answers
  • Posted on Feb 15, 2009
SOURCE: computer will not turn on at all. Dell Dimension 5100 desktop
I would unplug the power supply from the motherboard, wait a little while and then plug it back in.
Try to power everything back up and it should come up.
I am assuming you are getting a light on the motherboard that indicates power is being supplied?
Anonymous
  • 2653 Answers
  • Posted on Feb 21, 2009
SOURCE: dell dimension 2350 pc turns off and on repeatedly
Sounds like a bad mobo. 8 years! Damn let it die already LOL..!!!
Anonymous
  • 3 Answers
  • Posted on Jul 09, 2009
SOURCE: Dell Dimension 5150 will not boot. Flashes amber light
I had the same issue with my Dell Dimension 5150 and I replaced the front I/O USB Audio Panel and it booted right up.
2helpful
Power button on dell dimension 8200 is solid amber computer will not boot up what is it?
hi this looks like the hdd is not powering up...take the cover of the tower and disconnect the hdd power and see if the motherboard fires up on its owen......unplug the power to the motherboard and wait 5 mins plug it back in see what happens.......on the motherboard were you plug in the hdd led cables and power cable and the led cables and fined the one that has the pwr on it plug it in on its owen see if that helps you
1helpful
No power to tower. Pressing power on button on front of tower fails. Is there some kind of reset or fuse to look for?
There is no easy fuse. Did the computer get turned off at the back? Some power supplies have a switch on the top of the tower. Did the power strip get turned off? Have you verified that the outlet has power?
If this is not the problem, it sounds like a blown power supply. Do you have any lights on the system? If not, take the tower to a local computer shop and they can very quickly diagnose a failed power supply.
Dell Dimension B110 will not power on when front button is pushed. Plugged it into another outlet without using power strip....still didn't start...purchased New power supply and installed still nothing...
check the bezel/power button
try to open the tower but you have to make sure that its unplugged/ after unplugging the power cable press the power button for about 5 secs to drain the flea power then check the power button maybe its broken or the cable connected to the power button to the main board is damaged or loose.
Main power button LED is flashing or solid yellow
This is a major problem that crippled Dell. Moels Optiplex Gx260, Gx 280, and Dimensions of whose mdel number i don't remember have this problems. This signal shows that either a power supply or your motherboard is malfunctioning. If you have an insurance better use it now or else get some technical assistance.
2answers
Dell dimension 8200 flashing yeloow power button
Please find the complete error codes for dell 8200 and their fixes.
http://support.dell.com/support/edocs/systems/dim8200/codes.htm
This will help you to figure the type of error u are getting and its resolution.
Please feel free to rate this solution link.
2answers
Dimension 8200 will not turn on
Try a new power button. Also does the machine power light turn on at the front of the machine? if so check that the CPU is seated correctly as if it has come out of position then the machine doesn't boot. I would like to think power switch though.
Thanks J
Grand Canyon Tech
Grand Canyon Tech
SmartAviator
SmartAviator
