Printer will not print. Says it is off line. Anyway to get it online?
When you want to print a document and messages looks to state that the Dell printer is offline. Well, it occurs problems with any type of printer model or brand. This problem requires a lot of technical steps that must be followed by the printer used and explain below:
1. Find Windows services.
2. Move right down to notice perform Host and performance.
3. Check the standing and from there move to Startup kind columns.
4. If the printer is running then move to the ensuing step.
5. If printer columns represent empty, right-click the name and choose Properties.
6. Change the beginning to automatic.
7. Then click on the service standing and click on OK.
8. Next, come to the "Device and Printers" window and press F5.
9. Click on the name of your dell printer and check the status.
Every time , when printer says, offline, that means there is something wrong between the connection. so you should try to follow the instructions bellow to get your account back. How Do Fix Dell Printer Say Offline Using Windows Laptop Fixotip
Any user can start printing the documents after adding a USB or a networked printer to the system and by sending the necessary documents to the printer.
If the printer creates an error message that shows offline mode, you may need to change the offline mode to online mode.
For this, you may need to perform certain steps.
Click on the 'Printers and Faxes' icon after opening the 'Start' menu.
This may show you all the printers that are connected to your system at that time.
You may need to double click on the printer icon in order to change it to online.
A popup may arise and you have to go to 'Printer' option in the menu bar of popup window and uncheck 'Use Printer Offline'.
This may make it to online mode.
Get more information to fix Dell Printer Offline Error . Hope this helps you.
In Control Panel - Printers, Right-click the Dell 1710N and remove check for Offline.
