Computers & Internet Logo
Posted on Jun 05, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Menu screen popping
The menu screen starts popping every now & then...the brightnes & contrast keeps on varying according to its wish....those menu buttons dont work...
Anonymous
Level 2:
  • Expert 52 Answers
  • Posted on Jun 14, 2009
Anonymous
Expert
Level 2:
Answers
52
Questions
0
Helped
19553
Points
102
The up/down button on your flat panel is stuck. Please contact Dell Technical Support to have the monitor replaced if its still within warranty.
HOW TO SET BRIGHTNESS OF THE SCREEN?
Dear User...
You can adjust the brightness and contrast of your monitor to improve the readability of text and to make digital pictures appear more like they'll look when printed.
To improve the results when adjusting the brightness and contrast settings for your display, use Display Color Calibration. (Display Color Calibration helps you adjust these color settings and others.) For more information about calibrating your display color in Windows, see Calibrate your display.
The way you adjust brightness and contrast varies and depends on your specific display.
Brightness and contrast buttons on the front of the monitor. Some monitors have brightness and contrast controls on the front and use the standard symbols shown in the following image.
On-screen menu. You can change the brightness and contrast settings for some displays by using an on-screen menu, and then setting the brightness and contrast in the resulting menu. Many times, you can view the on-screen menu by pressing a button-possibly labeled Menu-on the front of the monitor.
Thanks....
3helpful
Brightness/contrast menu pops up in middle of my screen and won't go away....
press the menu button and keep pressed for 20 second untill menu does not show unlocked menu massage your problem will be solved
I have a small screen which appears in the middle of my main screen which is for adjusting contrast ect. I keeps popping up I can not remove it there are buttons in the front for exit ect which will not...
Sounds like the monitor menu is popping up. If so, it is not your computer but the monitor that is causing the problem. Is the monitor menu button stuck?
How can make brightnes
Go into the Menu Key " Look for Copy Quaility or Copy Density "
Change that from normal to Darker and change the contrast to darker you should see a difference. Incase you can't find it Print the Menu Map Look under Media OR Reolution it should be there. Again print Menu map to find it
34helpful
2answers
HCL Monitor Screen Display Problem with Contrast menu showing up.
my hcl 17inches monitor is displaying contrast,brightness etc automatically
in the middle of the screen.even if i press the menu buttons it
disappears for a sec and comes again and again.what should i do to
solve this?
4helpful
2answers
Brightness/contrast window pops up and scrolls through fast
Menu keeps popping up
Never a good idea to clean with any spray cleaner. The cleaner does get down in the button bar and cause corrosion and shorting along ribbon cable. Use screen wipes for computer monitors only on TV's and any type of monitors. You can remove the back of the case. And remove the button board and clean with a cue tip and alcohol along ribbon cable.
Grand Canyon Tech
Grand Canyon Tech
