Hitachi 42HDT79 42 in. Plasma Television Logo
Posted on Jun 04, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Flashing green light
We have 60" hitachi plasma and when we turn it on we get no picture and sound for about 5 seconds then nothing and the green light starts flashing???? we have had the tv for thirteen months. help
Ginko
Level 3:
  • Hitachi Master 19,396 Answers
  • Posted on Jun 04, 2009
Ginko
Hitachi Master
Level 3:
Answers
19396
Questions
25
Helped
8078015
Points
55462
The TV is on protect mode. This happens when an internal fault is detected. Start leaving the TV unplugged overnight. This will drain power discharging capacitor and internal circuits, and sometimes can solve minor problems. If the TV still does not start , it must be taken apart and tested. Parts that commonly fail are the PSU, controller board, low buffer and sustain boards. If the TV is only 13 months old, then it is worth calling Hitachi and asking for a warranty extension or a discounted repair. Regards.
I have a hitachi 55pma550 plasma tv.when I turn on the main switch red light comes on standby. But when I turn on tv the red red light on stand by turns green only for 10 seconds and goes red no picture...
It's most likely the smps. You'll first need to check voltages at CN63, pin #1-(+5v), 3-(+3.3v) and pin 8-(+6v) Also check CNPPS, pin 1-(+30v), 4-(+5v), 8-(+12v), 12-(+10v) absent these values and the power supply is clearly the problem.
42 inch hitachi plasma
the more the tv remains on the picture gets out of focus mainly in the midle of screen. Sure sounds like tv needs some light engine repair or replacement.
Hitachi Plasma Model PD32-A3000/AVC-A3000
vertical red line on screen - I have a Hitachi plasma 42HDs69
2helpful
2answers
2answers
Plasma wnt stay on
I have had this problem in some models of plasma sets before. In most cases the power supply and main drive boards had to be replaced. In a small number of cases the failure was the screen itself.
In all cases, the cost of the repair was expensive. For the screen failure, the set was scrapped.
Jerry G.
2helpful
3answers
Hitachi 60" picture flashes on and off.
I've had the same issue although I don't unplug everything. I turn it off and then unplug it from the wall for 10 seconds then plug it back in. Seems ok after that. Has happened 4 or 5 times over the 10 years I've owned it.
6helpful
5answers
TV Picture Goes Black
I had the same exact problem.
I removed the bulb and cleaned it. There is a small screen at the top of the bulb and it was covered with dust. Once it was cleaned I replaced the bulb and it solved the problem.
Thanks to those who posted the solutions
Top Hitachi Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
