Hitachi 60V500 60" Rear Projection HDTV-Ready Television Logo
Posted on Aug 11, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
42 inch hitachi plasma
All the people on my screen are green! Tried adjusting the color but it all stays green!
Anonymous
Level 3:
  • Master 476 Answers
  • Posted on Aug 11, 2009
Anonymous
Master
Level 3:
Answers
476
Questions
0
Helped
101157
Points
1473
The more the tv remains on the picture gets out of focus mainly in the midle of screen. Sure sounds like tv needs some light engine repair or replacement.
1helpful
Why does my Hitachi 42HDS69 42 inch Plasma TV have horizontal green lines across the screen? I have checked all connections and tried to tweek the color settings but nothing has helped. I went thru th
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Line, faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent.
I have a 42 inch Hitachi plasma tv that is making a very loud static noice coming from the internal speakers. It stays at a contstant very loud volume unless I completly mute the tv or turn the volum
Based on what you have tried if a buzz or loud static via the speakers you have something wrong in the audio output circuit of the set--problem here is that circuit may be part of the Main board that processes all signal---a look inside---following the speaker leads back would lead you to that board.
A simple thing to do to narrow it a little (you may have done this) is with sound all the way off put your ear to the internal speaker--hear anything at all like a deep hum?
Depending on age of set and cost of the board likely bad it may or may not be a do it yourself repair.
SD TECH
My 42 inch toshiba plasma tv. about 4.5 years
Ur backlight video inverter board is dead or defective,need it replaced.Tries these websites Shopjimmy.com or Partstore.com or Ebay.com.
1helpful
My plasma picture looks green
You are proberbly using RGB leads, wich is red green blue, each colour runs through each cable, have a look at your cables maybe one is loose, or damaged. check on both ends, but the cables MAY NOT be red green and blue, but the terminals that the plug into will be.
3helpful
3answers
Vertical lines on screen
1. Frist on the BURN MODE.
2. Check whether same
Vertical lines on screen ?? 3. If yes ..?
4. Then change the LOGIC BOARD or PDP
When I turn my hitachi plasma tel on I see lots of green dots all over the screen is this an adjustment problem or a part going out
I had the same problem with my Hitachi 42edt41. It was the Y sustain pcb. Large board on the left as you are looking at it from the back. Costs about $750. for the part.
Bill
HITACHI 42 INCH HD
Convergence Amp IC issue....originals are STK392-110..replace
W / upgrade Stk394-160E Hitachi part # CZ 01341 and check nearby resistors for overheating............................T.
2answers
Plasma wnt stay on
I have had this problem in some models of plasma sets before. In most cases the power supply and main drive boards had to be replaced. In a small number of cases the failure was the screen itself.
In all cases, the cost of the repair was expensive. For the screen failure, the set was scrapped.
Jerry G.
Hitachi 52 projection tv
use the advanced options page and reset the factor blue and red convergence defaults then do re apply the auto color defaults color at first it seemed very red (which is good because red was the missing factor in the green picture) but after reseting all the color and tints to the normal ranges I then reset the color auto correct again and all seems fine.
Top Hitachi Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
