1. Turn on the player
2. Wait for the no disc message
3. Press REPEAT 57538
4. The number 2 displays in the top left corner
5. Press 9 for multiregion.
I tried it on a number of discs including The Patriot R1 which has the RCE coding as well and it plays it.
R3 and R4 play too. This means I won't need my old DVD player now.
I should add it doesn't allow region A blu-rays. No surprise there.
thank you and good luck....
Hi. Making your Samsung DVD Player regionless is a little bit tricky, and it is not guaranteed to work either, since it is not an offiicial process :) You can try this:
The trick seemed to be not holding the repeat key too long.
For example, if your device is a Region B/4, running 080604.01_050708-1_XSA code.
Use the R4 code from below.
1) Turn on the player with no disc in the tray
Wait till the unit is at the Samsung logo screen.
2) Open then close the tray, wait to see the No-Disc Message in the top Left Corner
3) Now press the REPEAT button on the remote, followed by a five digit code.
In this case Repeat 76884
Now try to get this to work as many times it gets, It needed to be done without delay.
So if you don’t get it to work straight away don’t loose heart.
4) When it works a 4 will appear in the top left corner
5) Press 9 to make it regionless.
6) Press Eject to OPEN to open the disc tray.
7) Press Eject to CLOSE to close the disc tray.
8) Power the unit off
9) Now power the unit on again, it should now read all regions of DVD Disc.
This is the list of region codes.
R1 - 29334
R2 - 57538
R3 - 56732
R4 - 76884
R5 - 53814
R6 - 24462
Hope this helps.
Erinc
Sorry my player is different model... quite new!
Front:050
S/W:BEv1.10.090227_XAA
Loader: LDv1.08_090224
Region A/1(BD/DVD)
Macrovision:BBS51
Model BD-P4600_XAA
... the problem persists :-)
There is a way to set this area code like in every system (software).
Question is has it leaked out yet... I woul imagine Samsung would not mind
since there is no criminal what I am trying to do... quite contrary!
I will pay for information that leads to solution :-)
Sincerely,
Olli
