Mr. Heater MHU45LP Logo
Where is the LED lights thst flash located - Mr. Heater MHU45LP
I have an existing ceiling fan/light unit using the Intertek 3177973 unit. I want to install a second unit for the same light. How do I pair / sync the second remote switch to the existing receiver??
To pair/sync a second remote switch to an existing Intertek 3177973 receiver, you will need to follow these steps:
  1. Turn off the power to the existing fan/light unit by switching off the circuit breaker or removing the fuse.
  2. Locate the "learn" button on the receiver. It is usually located on the back of the receiver or the control box.
  3. Press and hold the "learn" button on the receiver until the LED light on the receiver starts flashing.
  4. Press the "on" button on the new remote switch for about 5 seconds. The LED light on the new remote switch should start flashing.
  5. Release the "on" button on the new remote switch. The LED light on the new remote switch should stop flashing, and the LED light on the receiver should stop flashing.
  6. Test the new remote switch to make sure it is controlling the fan/light unit properly.
7. Turn on the power to the existing fan/light unit.
It's important to note that these steps are general guidelines, and the specific steps may vary depending on the model of your Intertek 3177973 remote control unit. Consult the manual for the specific steps and precautions before pairing or syncing on your remote control unit.
Jan 11, 2023 • Home
2answers
DC Blue and PLUS reset ? remote lost, connect new but memory full
If you have lost your remote for your DC Blue and PLUS garage door motor and need to connect a new remote, but the memory is full, you will need to reset the motor to clear the memory before programming the new remote.
To reset the DC Blue and PLUS motor, follow these steps:
  1. Locate the reset button on the motor. It is usually located near the bottom of the motor and may be labeled "Reset" or "Learn".
  2. Press and hold the reset button for about 10 seconds until the LED light on the motor flashes rapidly.
  3. Release the reset button and wait for the LED light to turn off. This indicates that the motor has been reset and the memory has been cleared.
Once you have reset the motor, you can program your new remote by following the instructions in the manual. If the memory is still full and you are unable to program the new remote, you may need to delete some of the stored remotes from the motor's memory to make room for the new remote.
To delete stored remotes from the motor's memory, follow these steps:
  1. Press and hold the "Learn" button on the motor for about 10 seconds until the LED light starts flashing.
  2. Press the button on the remote you want to delete from the memory.
  3. Wait for the LED light on the motor to flash rapidly, indicating that the remote has been deleted from the memory.
Repeat these steps for each remote you want to delete from the memory until you have enough space to program your new remote.
If you are still having trouble programming your new remote or resetting the motor, you may need to contact a professional technician for assistance.
1helpful
Kenwood stereo flashes E-04 when cd inserted
usually on the front of the stereo unit theres a pin hole button that can only be pushed with a sharp pencil or a paper clip if you cant' find its location try search Kenwood website to locate the pinhole reset buttons location on thst units model number. Once you find it and engage it you should hear its' internal mechanics move around and it should be completely reset and possibly work.
Blinking lid locked light and green sensor light on machine won't start cycle
The good ol' Whirlpool Lid Lock Flashing Light Problem - ApplianceBlog
www.applianceblog.com/.../42456-The-good-ol-Whirlpool-Lid-Lock-Fl...
Dec 11, 2013 - 10 posts - ‎3 authors
Red Lid Lock light flashing intermittently when you try to start a cycle. ... I'm going to post what SENSING does first, then you will need to locate your tech. ... start with thelid lock on and blinking, or the unit will not start and spin. FIXED Sense light on light humming noise won't start ...
Aug 9, 2015
Whirlpool WTW4950XW not working
Nov 2, 2013
Stacked GE washer/dryer lights Blinking doeent start at ...
Feb 20, 2012
More results from www.applianceblog.com
Washer Sensing led (Green) on with the lid locking led (Red ...
www.shopyourway.com > Manage My Life > Questions
... this: Sensing led (Green) on, the lid locking led (Red) blinking with a clicking noise ... red led light goes off green led light stays on and the washer does not start.
Whats wrong with my hl61a750a1fxza tv it wont come on led light flashes then i hear a click and all three lights start flashing.
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. http://electronicshelponline.blogspot.com/
Blinking codes details to many popular brand TVs are given. Surf the site with patience.
When I power up the printer it lights the red led indicating problems with the ink cartridge i saw a video before thst helped me to solve this problem resetting the printer coulyou help me pls
replace the cartridges with replacement or re-sit the cartridges, and if not helping, uninstall everything and reinstall basck up everything , the whole packet
Hello I have a 1994 maxima manual transmision,it have a check engine light on,when I start the car and beguin to drive it,runs perfect the a few minutes later the car gets very lazy almost want to turn...
Hello! I'll need the trouble code to fix your vehicle...Below is procedure with a code list...Guru...saailer
Remove the trim panels in front of the center console. Locate the engine computer attached to a floor-mounted bracket on the transmission tunnel between the console and the firewall.
  • Turn the diagnostic mode selector, located in a round opening on the side of the engine computer, until it stops. Observe the small red and green LED lights on the side of the computer next to the mode selector. They will flash to indicate the modes, with a pause between each mode. One quick flash is mode one, two quick flashes is mode two and so on. When the light flashes indicate mode three, quickly turn the mode selector counterclockwise until it stops. You have entered mode three diagnostics.
  • Remove the trim panels in front of the center console. Locate the engine computer attached to a floor-mounted bracket on the transmission tunnel between the console and the firewall.
  • Turn the diagnostic mode selector, located in a round opening on the side of the engine computer, until it stops. Observe the small red and green LED lights on the side of the computer next to the mode selector. They will flash to indicate the modes, with a pause between each mode. One quick flash is mode one, two quick flashes is mode two and so on. When the light flashes indicate mode three, quickly turn the mode selector counterclockwise until it stops. You have entered mode three diagnostics.Observe the red and green LED lights on the side of the computer. The red light flashes to indicate the "Tens" digit of the code and the green light flashes to indicate the "Ones" digit of the code. For example, if the red light flashes two times and the green light flashes seven times, this would indicate code 27.
    Turn the ignition key off for two minutes to exit diagnostics. The computer will automatically return to mode one for normal operation...
    Code 11 Crank sensor angle
    Code 12 Mass airflow sensor
    Code 13 Engine coolant temperature sensor
    Code 14 Vehicle speed sensor
    Code 21 No ignition reference
    Code 22 Fuel pump
    Code 31 Engine control unit
    Code 32 EGR sensor
    Code 33 Oxygen sensor
    Code 34 Knock sensor
    Code 35 EGR temperature sensor
    Code 43 Throttle position sensor
    Code 45 Injector leak
    Code 51 Injector circuit
    Code 54 Automatic transmission signal
    Code 55 No malfunction recorded
    I’m happy to help further over the phone at https://www.6ya.com/expert/david_6df67de3b14de867
    9helpful
    3answers
    I have a golden companion scooter and it wont move it flashes a green light but i haave no info on where to obtain the trouble codes
    The L.E.D. located on the tiller
    dashboard will indicate with flash codes what problem is occurring.
    L.E.D. Flashes 1 time and pauses, 1 time and pauses…. Batteries are low,
    scooter will still operate.
    L.E.D. Flashes 2 times and pauses, 2 times and pauses…. Batteries are very
    low, scooter will not operate.
    L.E.D. Flashes 3 times and pauses, 3 times and pauses….Over voltage to
    controller.
    L.E.D. Flashes 5 times and pauses, 5 times and pauses….Brake is in the
    freewheel position or connection to brake is open.
    L.E.D. Flashes 6 times and pauses, 6 times and pauses….Paddle or speed
    potentiometer problem.
    L.E.D. Flashes 7 times and pauses, 7 times and pauses….Paddle or speed
    L.E.D. Flashes 8 times and pauses, 8 times and pauses….Motor
    disconnected or faulty.
    L.E.D. Flashes 9 times and pauses, 9 times and pause….Controller fault.
    I hope this helps they are pretty standard codes I got this from Golden Tech Web Site
    1helpful
    2answers
    I've got a honda cbr600rr 07, I've fitted LED indicator lights to the bike and resistors to slow the indicators down, however their still flashing to fast so ive read up to change the relay, I've found...
    the thing that controls your indicators should make a clicking sound when they are turned on, try changing your bulbs back to the stock lights, if that makes no difference replace your unit :)
    2answers
    The light on the ps3 gose green yellow and the flashs red
    the yellow light in the front of the ps3 means that it is accessing the hard drive in the ps3 the green light means thst it is connecting/trying to connect to a wireless /wired internet connection
    Top Mr. Heater Heating & Cooling Experts
    Paul Carew
    Jay Finke
    Jay Finke
    Are you a Mr. Heater Heating and Cooling Expert? Answer questions, earn points and help others
