Question about GPX D516 Clock Radio
Mains frequency is lower
I brought the clock into India and used a voltage converter. However, the mains frequency is 50 Hz and the clock runs slow. What can I do? Is it possible to change the clock locally without touching the IC?
Vijay
rvijaykr@hotmail.com
  • rvijay Oct 23, 2007
    Great help. fred.
    Thanks
    Vijay
Open the case and look at the clock ic.  find the datasheet on the internet. this usually involves placing a jumper to ground for 50Hz operation and opening a jumper for 60 Hz operation.
Posted on Oct 23, 2007
SOURCE:
Can I use my Weather Forecaster #00821SBDI successfully overseas where the mains frequency is 50Hz. I can take care of the voltage difference.
Read the fine print on the power supply (the part that plugs into the wall). You may find 120-240 V or VAC, meaning that you don't need any converter - just a plug adapter. You'll probably also find 50-60 hz as the frequency range, meaning that you're good to go with just a plug adapter.
Feb 28, 2018 | Forecaster Measuring Tools & Sensors
Losses Time
what frequency does Jordon use on their power is it 50 hz are the clocks 60 Hz designed power usage.
may need a device to convert 50hz to 60hz
search google for
50 hz to 60hz frequency converter
Apr 15, 2014 | Sanyo R-6800 2-IN-1 ALARM CLOCK AND RADIO...
How to use US bought cordless phone to work in India? Model Name : Motorola L603 M
no need to worry about frequency it will take care by voltage converter. you just need a good quality converter. and no need to buy 3 converters for 3 handsets. just buy one converter and one Multiplug or extension cable and connect it to converter's output socket and put your base power supply and other handset's chargers in and you are good to go.
Nov 27, 2013 | Lands Phones
Need to transform 120v power to 240v
Bad news:
UK has 50 Hz electricity, and appliances are rated for local power..
Any appliance made for US market is rated 60 Hz.
50 Hz and 60 Hz electricity are different.
Look at label on your mixer, and then look at labels on local appliances. You will see 50 cycles or 60 cycles. Rarely appliances are labeled 50-60 cycles.
http://www.worldstandards.eu/electricity.htm#voltage
http://waterheatertimer.org/See-inside-main-breaker-box.html#Hz
http://waterheatertimer.org/What-is-3-phase-electric.html#120-240
Hz Hertz or cycles or frequency is number of rotations the electric generator turns per second.
Some appliances are rated 50-60 cycles and will work worldwide.
However most appliances are rated 50 or rated 60 but not both.
60 cycle motor will not perform as expected when connected to 50 cycles. And might overheat.
Generally, most motors can be converted to different voltages by taking motor to motor shop (if you can find one these day)
However electronic controls cannot be converted between 120V and 230V, nor will 50 Hz electronics work with 60 Hz power
Sorry Sue.
Buy another mixer.
Business will benefit from surge of consumer buying.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Mar 28, 2013 | Hardware & Accessories
I recently purchased an Audiovox Clock Radio CR20 from the USA on a visit to that country. I am back in my home country India and started using the clock radio. I find that the clock is not keeping correct...
The reason of your problem is that your local mains frequency is 50 Hz and when you use 230V to 120V converter, this simple device can not convert frequency only the voltage. Your clock is synchronized to the mains frequency which is 50 Hz instead of 60 Hz and the clock goes slowly. It is late (60-50)/60 ---> 10 minutes in every hour.
I am sorry but I think your problem can not be fixed. ( It would be possible to convert the frequency but the cost of this kind of device would be higher than the value of this Audiovox)
Thanks.
gylacz
Aug 10, 2011 | Audiovox Audio Players & Recorders
Bought oven in hongkong now in Philippines, how to
Ok, you cannot do that The "Frequency" of the mains cannot be changed. However IF the Voltages are the same the differing Frequencies will NOT stop it from heating etc. .BUT unfortunately it WILL matter to the electronics in it. The clock wouldn't run etc. So I think you maybe stumped? You could safely try it though? See if it works?
Feb 15, 2010 | Ovens
Uae customer
even if there is power difference, all you have to do is buy a transformer that would convert 110 volts to 220 volts or vice versa. another issue that to be consider is frequency.
if the unit is designed to run at 60 Hz, then it would be slower when plugged to a 50 Hz supply. and the reverse, it would be faster if it is designed to 50 Hz and plugged to a 60 Hz supply.
tnx 4 using fixya,
drcool
Sep 28, 2008 | Washing Machines
JCR-160 clock radio Clock running slow
The clock works off the frequency (hertz). In US the electrical wave frequency is 60HZ/sec and in India and many other countries 50HZ/sec. Hence, the clock slows down about 6 seconds or so every minute.
Mar 12, 2007 | Jensen JCR-425 Clock Radio
GPX D516 Clock Radio Logo
121 people viewed this question
Top GPX Audio Players & Recorders Experts
Joe Negus
Joe Negus
Are you a GPX Audio Player and Recorder Expert? Answer questions, earn points and help others
