It could be that your PC is having video issues booting. Find another monitor and see if it displays correctly. If it does, your original monitor is defective. If it doesn't, your PC boot has video issues (bad drivers, recently installed software causing conflicts with video card, etc.)
Did the laptop boot up all the way except the screen is blank? Do you
hear fans running and the hard drive spinning, lights on? If you think
it booted except the screen is blank try the steps below.
Shine a flashlight on the dark screen to see if you barely
see the icons on the desktop. If so, then the LCD Inverter is bad.
Plug in an external monitor and see if the display shows up on it. It can be
any kind of monitor even the old big fat crt monitors as long as it has a vga
cable to connect to your computer's vga port. If so that proves your
video card is ok. The video will show on most systems when you reboot
without you having to do anything. Some systems will require you to hit the FN
(Function key) + F1 thru F12. Hold down the FN key then hit the correct
key for displaying on the monitor (F1 thru F12). The correct key will
normally have CRT/LCD on it or it will have the icon of a display.
If you see no icons by shinning a flash light and the external monitor works,
then your screen is bad. If you see no icons by shinning the flash light
and nothing shows on the external monitor, then most likely your video card is
bad.
Does it sound like the computer booted up except the screen is black.
Do you hear fans running, the hard drive spinning? Maybe the system
booted up, but the screen has an issue.
bad.
Sounds like your monitor is bad. Try another monitor because if the video card was bad and the monitor is working you would get a No Signal message on the screen. Borrow a monitor from a neighbor, friend, relative or co-worker and connect it to the computer. If the Borrowed monitor displays ok, then your original monitor is bad. If the Borrowed monitor does the same as your original monitor and does not display anything, then there is an issue with your video card.
If the computer seems like it booted up and is running except the screen is black, try the steps below:
Shine a flashlight on the dark screen to see if you barelysee the icons on the desktop. If so, then the LCD Inverter is bad.
Plug in an external monitor and see if the display shows up on it. It can beany kind of monitor even the old big fat crt monitors as long as it has a vgacable to connect to your computer's vga port. If so that proves yourvideo card is ok. The video will show on most systems when you rebootwithout you having to do anything. Some systems will require you to hit the FN(Function key) + F1 thru F12. Hold down the FN key then hit the correctkey for displaying on the monitor (F1 thru F12). The correct key willnormally have CRT/LCD on it or it will have the icon of a display.
If you see no icons by shinning a flash light and the external monitor works,then your screen is bad. If you see no icons by shinning the flash lightand nothing shows on the external monitor, then most likely your video card isbad.
Does it sound like the laptop booted up except the screen is black? Do you hear the fan running and the hard drive spinning? If so try the steps below. Shine a flashlight on the dark screen to see if you barelysee the icons on the desktop. If so, then the LCD Inverter is bad.
Did it boot all the way? Do you hear the fan running, disk drive spinning? If it sounds like it booted but the display is black, try this: When you press the power button do you hear fansrunning, hard drive spinning, lights on the computer, hear any beeps or lightsconstantly blinking, hear the DvD/CD drive click and the light on the drawer ofthe DvD/CD turn on for a second or two? If so the laptop is trying toboot or may have booted, but the screen is not showing for some reason.
Beep tones and blinking lights tells the technicians what is going on with thelaptop and why it is not booting. Most times it's a motherboard issuewhen you hear beeps or blinking lights continuous.
Black screen? So does it look like it booted up fine or did it shut down? Does it look like the computer is running, but the screen is black? If so, then:
