Question about Sceptre X322BV HD 32 inch Class Television 720P HDTV LCD/ PC Monitor Black -
X322bv powers on but does not show screen
Why does the tv power up but does not show anything on the screen?
RS Technology Resources
    Scholar:
  • 111 Answers
It could be that your PC is having video issues booting. Find another monitor and see if it displays correctly. If it does, your original monitor is defective. If it doesn't, your PC boot has video issues (bad drivers, recently installed software causing conflicts with video card, etc.)
Posted on Sep 04, 2014
Sceptre 32 inch tv takes about 3 min. to power on and sometimes don't power on at all
Fault to the main power supply regulator section. Either it will be a separate board, or the part of main board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts.
http://electro-medical.blogspot.com/
It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time. Even though you can make it right, it will cost around an amount equal to the cost of a new board; including the cost of (spare parts + service charge) More to say, most of the spare parts to it will be difficult to get from open electronic spare part market. This is true to most of the flat panel TV power supply boards; irrespective of its brand and screen size.
Jun 14, 2016 | Sceptre X322bv-hd 32" 720p Hd Lcd...
FIX BLUE SCREEN ON LED TV
A blue screen usually indicates no video signal.
Jan 25, 2016 | Sceptre Televison & Video
Dark screen more so in the center
Sounds like the LED's are not getting enough power. The power board must be going bad.
May 29, 2015 | Sceptre X322BV HD 32 inch Class Television...
Screen don't light up
Just do a hard reset to this TV and check. Unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. This process must make it a hard reset. If it do not help you, contact the authorized service center. Its main board is likely to be faulty. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" or "Magazine" will make surf easy. Pull up older posts. Surf the site with patience. Do a search by type in the brand name of your device at its search box and press "Enter".
Jul 14, 2014 | Televison & Video
32 inch sceptre x322bv lcd tv wont show video, it turns on with the blue lcd to indicate it powering staying blue for 4 seconds then goes red while the lcd screen shows the sceptre logo for 1/2 second im...
Sounds like The main power supply regulator section circuit fault. Either it will be a separate board, or the part of main board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts.
Aug 15, 2017 | Sceptre X322bv-hd 32-inch Class Television...
X322BV-HD*WXC100
Warranty is usually 1 year parts and labor. Contact mfc for warranty service. likely main board.
May 28, 2013 | Televison & Video
SCEPTRE X322BV, HDTV BLUE LED COMES ON WHEN POWERING UP, BUT NO PICTURE OR SOUND
I have the X322BV-HD and with no warning had the same thing happen. I"ve scoured the net and found very little--just as here on this site. I just got off the phone with a tech support rep at sceptor and got the following information:
HOW TO DO A FACTORY RESET:
  1. (Tech said this will often work even though you won't see anything on the screen--as long as the blue light is still on!) On the remote, press [MENU] and then 3 - 6 - 9 - 8 (If it's accepted, the TV will turn itself off.)
  2. Wait 10 seconds.
  3. Turn the TV back on and it will be back to all factory defaults.
That didn't work for me. But the second option, a Power Cycle Reset did.
POWER CYCLE RESET:
  1. Unplug the power cord and wait 10-15 minutes (extremely important, I used a timer set for 16 minutes just to be sure).
  2. While it is still unplugged, press and hold the [POWER] button for at LEAST 30 SECONDS - DO NOT RELEASE!
  3. While continuing to hold the [POWER] button, plug the TV back in.
The second option worked for me and it's back on working just fine. Hope this helps!
Dec 10, 2012 | Sceptre 32 X320BVHD 32 LCD TV
TV screen screen's blank but it's on stand by. whenever using a remote it does not show anything.
Switch off TV manually, switch off power, remove plug and retry after 48 hours.If problem persists, please refer it to a qualified service technician.
Jul 25, 2012 | Televison & Video
Sceptre X322BV HD 32 inch Class Television 720P HDTV LCD/ PC Monitor Black - Logo
179 people viewed this question
Top Sceptre Computers & Internet Experts
Ekse
Dave Burton
Level 1 Expert
Are you a Sceptre Computer and Internet Expert? Answer questions, earn points and help others
