I now want to use these speakers with my desktop PC. I cannot find the instructions for connecting the speakers. How do I connect these speakers to my PC?
SOURCE: JBL PLATINUM SERIES SPEAKERS
It is possible, but you may run into a problem with the amplification to be able to hear the speaker. Without knowing exactly what your setup is the best I can say is to attempt to hook them up to your headphone jack and see how well they work. If you don't hear anything, you need an amplifier. If you hear a distorted sound, but volume is not an issue, use the line out jack and see if it is any better.
SOURCE: JBl Platimu series connected to a 5000 series compaq presario
The power plug is on the back of the Compaq monitor.
SOURCE: no sound from speakers
Probably.
Do they connect to the computer via USB or mini plug?
If mini plug, make sure you have the right jack on the back of the computer (there's two)
Then go into System Preferences ... select "Sound" and see if you can select something other than "Internal Speakers" - the computer may just not be aware that you want to use the external speakers ...
Are the speakers powered? Is there a volume control on the subwoofer, or an external fob with a volume control on it? You probably know this if you used them previously with your Compaq computer ...
For audio expertise and PA system help with feedback and noise, try our new DVD "PA Systems for Small Groups" at www.rexark.com
