Compaq FS 7550 17 in.CRT Conventional Monitor
Problems with Compaq FS 7550 17 in.CRT Conventional Monitor?
Keep your PC up-to-date. Get a Free Scan for Compaq's latest driver updates.
Troubleshooting and Support
Solved Problems for Compaq FS 7550 17 in.CRT Conventional Monitor RSS Feed Post a New Problem
LG CB553H Monitor
LG CB553H monitor has power and menu that sais no data. When I connect to a pc there is no display.
1 Solution
power button on monitor
I have a compaq 7550 the monitor won't stay on unless you hold the power button in as soon as you take your finger off...
STAFF 1 Solution
fuse blown repeatedly on CB553H-KL
i've got a fuse blown T5AH250V and i replaced it and the fuse blown again. what is the problem of my monitor? Can...
2 Solutions
monitor problem....
i've compaq monitor...the problem is the monitor has the OSD display but when i connect the vga cable to desktop the...
1 Solution
Horizontal Bright White Line in Middle of...
Here's what happened. I had just finished installing my webcam. I go downstairs for 3 or 4 minutes and I come back up. I...
2 Solutions
RE FPD1960 power issue
Hi I have no problem sending it to you but can you give me a quote? Thanks azucho98 Hi, I'm in the middle of moving so...
1 Solution
Gateway FPD 1830 LCD Monitor
When power applied, display briefly comes on -- then blanks off. Power light remains on.
1 Solution
Unsolved Support Problems
Unsolved Problems for Compaq FS 7550 17 in.CRT Conventional Monitor RSS Feed Post a New Problem
Power On problem - Compaq Presario 1200...
I'm building a digital picture frame using linux and an old laptop. When I put apart the laptop, I started having...
Post a Solution
No power
power supply not coming after replacing bad STR
Post a Solution
compaq
my computer has a default screen beacuse it got rebooted...so how do i make it become regular n at sized screen????
Post a Solution
Tips & Tricks
Post a New Tip
WikiManual
Post a New Chapter
Manuals & Guides
Post your Manual or Guide
Specifications
Key Features
Size17"
Max. Resolution1600 x 1200
Dot Pitch0.22 mm
Monitor TypeCRT
Technical Features
Form FactorDesktop
Audio OutputSpeaker(s)
Dimensions
Depth16.11 in.
Height17.41 in.
Width17.02 in.
Weight41.9 lb.
Warranty
Warranty1 Year
Compaq Contact Information
Main support number800-474-6836, 800-652-6672
Sponsored Links
Loading problems.
Top Experts
Ask Me
Benimur Guru
9 solutions
Ask Me
acharyulu Guru
2 solutions
Ask Me
IrishDrui Guru
1 solutions
Repair Service
Find Monitor Repairman Near You:
Browse the Repair Directory
Repairman, Get Listed FREE
