IBM Wheelwriter 30 Typewriter Logo
M
Margaret Lohry Posted on Jan 16, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Problem with code key
When we press the code key it sounds like it clicks, but it does not work. What can I do to fix the problem?
Dick O Reilly
Level 3:
  • IBM Master 3,594 Answers
  • Posted on Mar 24, 2014
Dick  O Reilly
IBM Master
Level 3:
Answers
3594
Questions
Helped
610390
Points
6852
Most likely your keyboard is seperating you will need to have it rebuilt.
DickyO
216-269-3918
2answers
How To Fix Error Code 0xc0000001 On Windows 10 ?
When we will install windows 10 then error code 0*c0000001 will keep popping.
The causes of error code may be
1. Damaged SAM file
2.
Damaged system files
3.
File system integrity compromised
4.
Damaged RAM
Here is method that will help to fix error code
Use Media Creation Tool to Perform Automatic Repair
Automatic Repair is a Windows feature that allows you to fix certain system problems preventing you from installing or starting Windows. It works by scanning your computer system for any potential problem and tries to fix it.
Step 1: Download the Media Creation Tool
Step 2: Boot your computer using the Windows 10 DVD, or the System Repair disc. When you're asked to press any key to boot, just press any key on your keyboard.
Step 3: Choose the right time and the keyboard type.
Step 4: Click Repair your computer. You'll see this at the lower left corner on your screen.
Step 5: Choose Troubleshoot from Choose an option screen
Step 6: Click advanced options
Step 7: Choose automatic repair
4answers
How to reset error code E000-0000 canon 2202
Something similar to this:
1. In standby mode,press the "Settings/Registration" key.
2. Press the"Reset" key.
3. Press the"Back" key.
4. Press the"Settings / Registration" key.
5. The service modescreen is displayed.
6. Scroll to Printerthen choose Clear
Use the"Back" key to exit Service Mode
2answers
The sound control is not working when i press Fn+F11/F12 . but Fn+other key is alright ..
Try pressing Fn with the arrow keys , if not go into Control pannel and change the Volume and sound control from there
Hoped i helped :)
2answers
What is error code 43 for AMC 5 on a mac?
Mac Error Code 43 occurs due to wrong OS Configuration or due to wrong installation. To Fix Mac Error Code 43, just read the easy steps are given below:
Easy Steps to Fix Mac Error Code 43
Step 1: Reset PRAM Settings
    ·First shut down your Mac computer.
    ·Meanwhile Mac is shutting down you need to prepare for pressing command+option+P+R keys all together.
    ·Now turn on your Mac and press command+option+P+R command before the screen with grey start-up appear.
    ·At this point of time hold all these keys until you hear a start-up sound for three times and then release all the keys. Step 2: Delete All Locked Files
    ·You need to navigate to Applications then open utilities and click on terminal.
    ·Now open the terminal and type chflags -R nouchg command on it.
    ·Now find at the bottom dock and double click on the Trash icon.
    ·Press command+A to select all the files in the trash folder.
    ·However, in case of you not able to find the terminal window, arrange finder window, so that you can see at least a part of terminal window.
    ·If you have done then press Return key on the terminal and empty the trash folder.
    After following these steps if you are unable to Fix Mac Error Code 43, then just dial our toll free Mac Technical Support Number 1-833-493-0111 and get instant help.
1 833 493 0111 How to Fix Mac Error Code 43 on Mac OS
Control key detected to be pressed in Microsoft Word
Sounds like either a faulty keyboard or the Ctrl key is stuck.
No audo device
Please follow the following steps to rectify this problem :
Step 1 .Reset the default BIOS settings:
You can try resetting the sound default in the BIOS. Here's how:
1. Turn the PC on. When the Windows logo first appears, press the F1 key or Dell key repeatedly until you see the BIOS setup screen appear.
2. Press the F5 key ( Setup defaults). In some other PCs depending on the manufacturer the BIOS at start-up will have one of the default options that have names such as - ‘Load Fail-Safe Defaults’ and ‘Load Optimised Defaults’.You will have to choose ‘Load Optimised Defaults’
3. Select Yes or OK, then press the Enter key on your keyboard.
4. Press the F10 key, then select Yes or OK to save the default settings. Press Enter.
5. Exit the BIOS and restart your system checking for sound.
( For most PC's entering the BIOS will be the same but if it differs for your system, consult the operating manual for instructions on entering the BIOS.)
If this doesn’t work go to step 2
Step 2 . Configuring on-board sound in the BIOS:
Some computers come with sound on the motherboard (on-board), and some computers use a sound card. The on-board sound setting in the BIOS has to be set according to your particular sound configuration. Perform the following steps to correctly configure the sound in the BIOS:
Look at the back of your computer and use one of the following three items to determine the proper sound configuration and sound setting:
If the plugs for the speakers and microphones are located next to the parallel, serial, or USB ports, then the computer has on-board sound. The on-board sound setting in the BIOS should be Enabled. If the plugs for the speakers and microphone are located away from the other ports and sit in an area by themselves, the computer has a soundcard. The on-board sound setting (if there is one) in the BIOS should be Disabled. If the computer has sound plugs in both locations, a
soundcard has been added to the computer that already contains on-board sound. The on-board sound setting should be Disabled. To enter the BIOS, turn on the computer and when the first screen appears, press the F1 key /Dell key repeatedly until the BIOS Setup screen opens. Use the LEFT and RIGHT ARROW keys to select the Advanced tab. Press the DOWN ARROW key to select Onboard Audio Options and press ENTER. If Onboard Audio Options is not available, select I/O Device Configuration and press ENTER. If Audio Codec is listed, select it and press ENTER. Select either Enabled or Disabled depending on your configuration and press ENTER. Press the F10 key and then press ENTER to save and exit Start Windows and check for sound. If there is still no sound, continue to the next Step.
Step 3 . Reload the current sound driver
To do this, follow these steps
1.Click Start, type Device Manager in the Start Search box, and then press ENTER.
2.In the Device Manager dialog box, expand Sound, video, and game controllers.
3.Locate the audio device that was included with the computer.
4.Right-click the device, and then click Properties.
5.Click the Driver tab.
6.Click Uninstall.
7.Make sure that the Delete the Driver Software for this device check box is cleared, and then click OK.
8.In the Device Manager dialog box, click the Action menu, and then click Scan for hardware changes.
You should see a message that a hardware device is being installed. Additionally, the uninstalled audio device is now present in Device Manager.
9.Close the Device Manager dialog box, and then determine whether you can hear sound.
If your computer came with a motherboard CD, the audio drivers should be on the disk.
If you don’t have the CD go to your computer manufactures web page to search for updated sound driver software. Read the instructions on the download pages carefully
before installing.
If there are no updated sound drivers available, use Microsoft's Windows Update feature. Connect to the Internet and try the following items until Windows Update opens:
1.Click Start, and then click Windows Update (if it is listed).
2.Click Start, click Settings, and then click Windows Update (if it is listed).
3.Click Start, click All Programs, and then click Windows Update (if it is listed).
4.Go to Microsoft's Web site and click Windows Update from the Downloads menu.
Check if the sound works now….if it still doesn’t work then most likely the sound card might be faulty.
I have installed win xp and when i m installing sound driver it tells that "no audio device found"
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;}
Do the following steps to rectify this problem :
6.Click Uninstall.
before installing.
The voice and sound on my laptop is not working dell d10
1. Turn the laptop on. When the Windows logo first appears, press the F1 key or Dell key repeatedly until you see the BIOS setup screen appear.
( For most system's entering the BIOS will be the same but if it differs for your system, consult the operating manual for instructions on entering the BIOS.)
The on-board sound setting in the BIOS should be Enabled. To enter the BIOS, turn on the laptop and when the first screen appears, press the F1 key /Dell key repeatedly until the BIOS Setup screen opens. Use the LEFT and RIGHT ARROW keys to select the Advanced tab. Press the DOWN ARROW key to select Onboard Audio Options and press ENTER. If Onboard Audio Options is not available, select I/O Device Configuration and press ENTER. If Audio Codec is listed, select it and press ENTER. Select either Enabled or Disabled depending on your configuration and press ENTER. Press the F10 key and then press ENTER to save and exit Start Windows and check for sound. If there is still no sound, continue to the next Step.
6.Click Uninstall.
If that doesnt work and you have an installation CD, the audio drivers should be on the disk.
before installing.
Blackberry 7100g
About fixed dialing
If you enable fixed dialing number (FDN) mode, your device only makes calls to contacts on your FDN list. Your device can dial emergency numbers in FDN mode, even if the numbers are not in the FDN list. If your service provider plan includes SMS, you can also send SMS messages to contacts on your FDN list
so if you have this enabled chances are you have to turn it off.
this is how you turn it on so you should be able to use it as a guide to turn it off.
Turn on fixed dialing
1. In the phone options, click FDN Phone List.
2. Click the trackwheel.
3. Click Enable FDN mode.
4. Type the PIN2 code provided by your service provider.
5. Click the trackwheel.
or if you wanna keep it on and add friends to the fdn
Add contacts to the FDN list
3. Click New.
6. Type a name and a phone number.
7. Click the trackwheel.
8. Click Save.
and finally some shortcut keys:
To open the phone, press the Send key.
To end a call, press the End key.
To call a selected contact or phone number, press the Send key. To call a speed dial number, hold the assigned key.
To add an extension to a phone number, press the X key. Type the extension number.
To call your voice mail access number, hold 1.
To type a letter in a number field, hold the Alt key.
To type the first letter on a key, press the letter key once.
To type the second letter on a key, press the letter key twice.
To turn on or turn off mute using the Mute button, press the Mute button.
To turn on or turn off mute using the keypad, press the exclamation point (!) key.
To turn speakerphone on and off during a call, press the period (.) key.
To change the volume during a call, roll the trackwheel.
15helpful
3answers
System sound not working on Dell Inspirion 6000 laptop
There are two sides of the problem. Hardware and software. To check whether the hardware is defective:
Try running the Pre-boot System Assessment (PSA):
1. Shutdown system
2. Press and hold on the "Fn" key.
3. Press the power button to turn the system on while holding on the "Fn" key.
4. Run the PSA until you get to the "colored bars". Then press "N" to say no.
5. Should you hear the beep codes, that means that the sound card is working fine. If you don't hear anything, then you need to replace your motherboard.
Now if your hear beeps that means that there's something wrong with the driver and audio settings. Do the following:
1. Right-click on My Computer then click on Properties
2. Click on Hardware then Device Manager
3. Click on the (+) beside Sound and Audio Devices
4. Right click on Sigmatel then click "Uninstall".
5. Go to support.dell.com
6. Click on Drivers and Downloads
7. Enter the Service Tag of your system (found at the bottom of your laptop)
8. Then download the audio driver. Just save it on your desktop first.
9. Restart the computer.
10. Install the driver.
11. Go to Control Panel -> Sounds and audio
12. Make sure that Sigmatel is the default sound device.
Please rate this solution if this helps.
Thanks,
ArnWuLF
Top IBM Office Equipment & Supplies Experts
Grand Canyon Tech
Grand Canyon Tech
Are you an IBM Office Equipment and Supply Expert? Answer questions, earn points and help others
