Question about IBM Infoprint 6500 Matrix Printer
Default username and password for IBM Infoprint 6500
Posted by jkuriwchak on
Anonymous
    New Friend:
Username is root and there is no password if you are going in through the GUI. If for some reason that doesn't work try root as the username and blank as the password.
Posted on Feb 03, 2011
Good day how do I fix a problem on the IBM 6500 printer not powering up. The power supply has been to be OK. The main board has been replaced. The fans are not running etc.
If you replace the main PCB you need to move the Key over or it won't post (grey squares on the panel with no fans on). It is a small 3-pin plug near the flash memory slot.
In addition to that if you have the V5 controller you would need to move the Flash memory chip and the DRAM.
After you do that you will need to load the microcode on the PCB. I can get you instructions to do this.
V5 MRP provides IT Parts Product Supplies and Services
V6 MRP provides IT Parts Product Supplies and Services
Sep 14, 2015 | IBM Infoprint 6500 Matrix Printer
As400 LAN printer. queue has status of wrt but does nothing. can ping printer. have end/start writer, turned printer off/on, varied off/on. still will not print.
I'm assuming that you are using an IPDS device description. If so your Ethernet card need to have the defaults reset. There is an option to do this via the printers web interface.
Apr 23, 2015 | IBM Infoprint 6500 Matrix Printer
How do I reset the username and password to the default settings.
Press either delete or f2 during the boot up process to enter BIOS scroll down to set user password or supervisor password you can change or remove your password from there
or control panel user accounts
A user with a computer administrator account can create or change passwords for all users on the computer. Users with limited accounts can create and change their own passwords, as well as create password hints.
hope this helps
Oct 29, 2010 | IBM Infoprint 1650 Laser Printer
IBM 6500, printer won t put paper on first line.
I can supply you with the motor if needed. Please contact me @ 708-597-4222
Rory
Jun 16, 2009 | IBM Infoprint 6500 Matrix Printer
Change setting
You hace to save settings in the config menu, sometimes they dont save so its better to change settings by using web brouser and pc.
Feb 18, 2009 | IBM Infoprint 6500 Matrix Printer
Printing problems (InfoPrint 6500/iseries)
need more info plesae give me the most information on type of equipment and software issues and driver setting if you know and version of software may be helpful infor mation
contact threw this web site
rod the candymangandy
Feb 03, 2009 | IBM Infoprint 6500 Matrix Printer
To add paper size in IBM infoprint 6500
Start,
Settings,
Printers or ..,
Files,
Server Preporties
and a create new form
matrix or inc
Dec 19, 2007 | IBM Infoprint 6500 Matrix Printer
IBM Infoprint 6500 Matrix Printer Logo
Top IBM Office Equipment & Supplies Experts
Alan Matzke
Alan Matzke
efs_perpends
efs_perpends
Are you an IBM Office Equipment and Supply Expert? Answer questions, earn points and help others
