Check your owners manual for your remote locking features.
It may be quite normal for a key fob to only open the drivers door...opening all the doors when you only need the drivers door open may present a security threat..anyone could enter your vehicle before you had a chance to secure the open doors. You should be able to unlock the doors you need open from the drivers door console.
www.liftmaster.com/.../en.../tucmanuals/114a3044.pdf
Chamberlain GroupFasten the manual near the garage door after installation. .... This garage door openerhas been designed and tested to offer safe service provided it is installed, ...
CraftsmanCraftsman has the best selection of Garage Door Openers in stock. Get the Garage Door Openers you want from the brands you love today at Craftsman.
Craftsman1/2 hp Chain Drive Garage Door Opener Opens by Remote, Inside and from Car Enjoy a great end to every day by ... Owners manual - English (Warranty).
Koss XJ310 Shelf System Door not open - Questions - Fixya
www.fixya.com > ... > Koss > Koss XJ310 Shelf System
Question about Bang and Olufsen Audio Shelf Systems ... ...not opening. sign on screen,is flashing door.after pressing select button,sign disappears.door does not open The ... The cd player will not open when you press the open close button.
cd player door opens closes itself Audio Shelf Systems ...
www.fixya.com > Forum > Tags > cd player door opens closes itself
Get free help, advice & support for popular audio shelf system brands. ... CD player model SA248 the doors opening and closing mechanism does not work. ... flashingdoor.after pressing select button,sign disappears.door does not open The .
JVC MX-K30 CD Shelf System Cd door not open ... - Fixya
www.fixya.com > ... > JVC > JVC MX-K30 CD Shelf System
Question about Philips Audio Shelf Systems. 1 Answer · CD player door not opening. CD player door not opening when pressing cd open and closing select button ...door.after pressing select button,sign disappears.door does not open The .
? 9:21
https://www.youtube.com/watch?v=FngAg3mk2Ug
Apr 27, 2008 - Uploaded by Eric Barr
When CD and DVD players stop working, its usually because of the drawer not opening and/or shutting ...
? 2:03
https://www.youtube.com/watch?v=Gs3eC8E-gbU
Sep 6, 2014 - Uploaded by craiwin
I fixed my 1997 Ford Explorer Door won't open problem! ... I have the same problem but my passenger side door on my 2001 Ford Explorer locked and won't open smh ... will this work for the rear passenger doors? ... How to Replace Rear Inside Door Handle Latch Cable 2002-05 Ford Explorer Mercury ...
? 0:30
https://www.youtube.com/watch?v=oY4IcNdGK68
Apr 5, 2010 - Uploaded by gdellinger
A couple weeks ago the door handle just stopped working on the... 98 Ford Explorer Door Won't Open Part 1 ... The remote would open all other doors. ... on a Ford Exploer 91-2001 - Duration: 7:27. by diversity2 37,309 views.
? 4:22
https://www.youtube.com/watch?v=lJ0Fsh3561s
Jan 1, 2013 - Uploaded by inwinblades
98 Ford Explorer Door Problems- how to open without panel removal. inwinblades .... HELLO panel removal??? door won't open... Been searching all ... ok this better work on all doors, im aboutt o try this on my rear passenger door. .... I didn't care about the plastic door handle so i just "busted" it to pieces.
see this causes and fix it. God bless you Open Lever
If the microwave door won't open the open
lever might be broken. This part can be replaced separately.
Door Spring
If the microwave door won't open the door
spring may have broken. The door spring is located inside the door and
keeps downward pressure on the door hook.
Door Latch
latch might be broken. The door latch is inside the microwave. The door
hook, which is part of the door, engages with the latch to keep the door
closed during operation. If the door latch or actuator breaks the door
may not open.
Door Hook
hook might not be releasing properly. The door hook is installed inside
the door and normally releases when the door is opened. The hook is made
of plastic and will break over time. When this happens it will need to
be replaced, it can't be repaired.
Button Spring
If the microwave door won't open the button
spring might be broken internally. The button spring can be replaced. Button
If the microwave door won't open the button might be broken internally. The button can be replaced.
Handle Actuator
If the microwave door won't open the handle
actuator might be broken. This is a plastic part which can become
brittle over time. This part is connected between the door button and
the door latch assembly.
Parts are available at a salvage yard. Getting the door open is going to be your problem "unless" you pull the seat out and have room to take door panel off to open the door with the mechanism manually.
I'm not sure about the noise, but the jerking motion might be because your the center roller (located in the rear middle of the sliding door) has worn out and need to be replace. This is a will known problem.
Your problem is very hard to answer because 05-10 odyssey has so many problem with sliding door.
rear latch:
-door not to latch close
-door not to work
front latch:
-door not to open
lock actuator:
-door not to open
-door will pop when opening
window motor:
-window not to work
-door will only open half way
center roller:
-jerking motion when opening
-door kick back close while opening
-door kick back open while closing
If you press and hold the smart/learn button for 6 seconds on opener number 1 it will erase the memory and neither code will open it. Now just program it for button number one and you should be set. If you have remotes for door number 1 you will have to reprogram them also.
ok check the sliding door on the side the fuel door is on. there is a safety mech. there the door needs to be closed all the way. if its not you can't open the fuel door. so slam that door then find out where and how it keeps the fuel door from opening. because if you open the door with the fuel door open it may damage fuel door
