20 Most Recent Samsung SMH9187 Microwave Oven Questions & Answers
This problem is caused by a microswitch that is sticking in the closed position. Inspect and replace the defective microswitch in the latch assembly.
Samsung SMH9187... | Answered on Dec 01, 2017
SE means you have a shorted membrane keypad.
Actually the best overall solution to this problem is usually to order a new controller assembly (control box) and install it yourself. It's pretty simple.
We have a similar service manual and have uploaded it to our site here to help you.
Your part numbers may be different, so you can find helpful exploded views by entering your actual full model number at the Sears parts direct Web site here.
At Web site , they have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
Some connectors on the relays may have a lock:
Samsung SMH9187... | Answered on Aug 21, 2016
If the internal fuse in the microwave is good, then it could be a bad wiring connection somewhere in the oven, or a thermal cutout has failed.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/david_29ad5d1dd86564b0
Samsung SMH9187... | Answered on Jun 19, 2016
Remove power and clean the inside while checking if there are food particles on the inside or in the Wave-guides- the portion where the Magnetron is fitted. Also remove the main cover and clean the areas of the Magnetron , check for loose joints,Finally check if the main capacitor is faulty. Other wise you will need a check on the main board, and also the Magnetron for leakage.
see this causes and fix it. God bless you
Open Lever If the microwave door won't open the open lever might be broken. This part can be replaced separately.
Door Spring If the microwave door won't open the door spring may have broken. The door spring is located inside the door and keeps downward pressure on the door hook.
Door Latch If the microwave door won't open the door latch might be broken. The door latch is inside the microwave. The door hook, which is part of the door, engages with the latch to keep the door closed during operation. If the door latch or actuator breaks the door may not open.
Door Hook If the microwave door won't open the door hook might not be releasing properly. The door hook is installed inside the door and normally releases when the door is opened. The hook is made of plastic and will break over time. When this happens it will need to be replaced, it can't be repaired.
Button Spring If the microwave door won't open the button spring might be broken internally. The button spring can be replaced.
Button If the microwave door won't open the button might be broken internally. The button can be replaced.
Handle Actuator If the microwave door won't open the handle actuator might be broken. This is a plastic part which can become brittle over time. This part is connected between the door button and the door latch assembly.
Samsung SMH9187... | Answered on Oct 27, 2015
see the steps and fix it. God bless you
  1. Main control boardIf your microwave runs for a few seconds and stops, the first thing to check is the main control board to ensure that a shortage has not occurred. If the part is defective then it will need to be replaced to prevent continual shut offs. If this is not the issue, the next step would be to check for a faulty touchpad.
  2. Touchpad/Control panelIf the control board is not the issue and your microwave continues to shut off after running for only a few seconds, the next thing to check is your touchpad, which is also known as a control panel. Although uncommon for this issue, symptoms are usually that the display and some buttons are working properly; however, when selected some buttons are not functioning. If this is the case the touchpad will need to be replaced.
Samsung SMH9187... | Answered on Jan 03, 2015
Had the same problem on my Samsung SMH9187. The two latches are cheap plastic. After watching a video on U tube on how to get the door apart, I fixed it with a paper clip and ordered the parts online (two years later I still have the paper clip holding the plastic latch in place). Look for the SE error to happen next, its not made very good.
Samsung SMH9187... | Answered on Sep 03, 2014
First you have to remove the trim from the top, there are two screws holding that and then a bit of gentle prying/wiggling. If you're having trouble with the unit randomly resetting, try torquing the exposed screws behind the control panel. The important one is probably the grounding point. It seems to have done the trick for me, three weeks and no SE- codes.
Samsung SMH9187... | Answered on Aug 31, 2014
the filter needs a good cleaning
Samsung SMH9187... | Answered on Aug 19, 2014
open the microwave cover & check micro switch attached with door lever.it may be displaced or damged. replace it
Samsung SMH9187... | Answered on Jul 07, 2014
the latch might be stuck or broken replace it and the problem is solved
Samsung SMH9187... | Answered on Mar 05, 2014
please check the fuse - you will be able to locate it on panel. - replace it and the pcs is ok --
Samsung SMH9187 Microwave Oven Logo
81 questions posted
Top Samsung Microwave Ovens Experts
William Miller
William Miller
Gerry Harvey
Gerry Harvey
Steve Allison
Steve Allison
Are you a Samsung Microwave Oven Expert? Answer questions, earn points and help others
View Most Popular
  • Samsung Microwave Ovens
Most Popular Question
fix se in control panel microwave
  • Microwave Ovens
