MSI EX465 Notebook Logo
A
Anonymous Posted on Jan 06, 2014
Auto shutdown - MSI EX465 Notebook
1helpful
2answers
Wont start2004 dodge grand caravan sxt code p0685 show on dash
P0685 DODGE - Auto Shutdown Relay Control Circuit Failure
Possible causes - Faulty Engine Control Module (ECM) power relay
- ECM power relay harness is open or shorted
- ECM power relay circuit poor electrical connection
- Faulty (ECM
Possible symptoms:
Engine Light ON (or Service Engine Soon Warning Light) P0685 Dodge Description: Short or open in Auto Shutdown (ASD) relay circuit, this relay is under the hood in the relay center.
How to turn off auto timed shutdown of calculator power to get constant power when calc is not in use
I don't think there is a way of turning off the auto timed shutdown. You can cover the solar cells, which will probably cause it to shutdown earlier.
Good luck,
Paul
Hi, i have an APC UPS with model BE 500R PH how to bypass the auto shutdown of it?
On mine, until an electrical storm, was controlled through my computer via USB. Now, it shuts down in 5 seconds. I'm sure it's the thermistors, but I don't have time. Also, check for timing circuits.
1helpful
Whats the codes p0685 an p0688 on a 2004 chrysler pacifica mean
P0685 CHRYSLER - Auto Shutdown Relay Control Circuit Failure
Symptoms
- Engine Light ON (or Service Engine Soon Warning Light)
Possible Causes
- ASD relay circuit is open or shorted
- Failed Auto Shutdown relay
- Failed ECM
Tech Notes
Check all the ECM fuses, if the fuses are OK try replacing the ASD relay.
P0688 CHRYSLER - Auto Shutdown Relay Control Circuit Low
The Front Control Module (FCM) has detected the supply voltage below an acceptable value
Symptoms
Possible Causes
- Failed ECM
Tech Notes
Disable auto shutdown
Restart the Computer and keep tapping the F8 key till you see the advance boot options, You should be tapping the key as soon as you see the manufactures screen. Once you get the advance boot options -> Select the option which says Disable Automatic Startup on System Failure.
Good Luck!!!
4helpful
2answers
Why does Infocus IN102 projector auto shutdown after a few minutes and indicator light blinks red.
Is it possible to repair the controller board some how? Replacement is not an option because I have approx 100 projectors of this model and X16 lying with me, requiring immediate repairs...
I have a 2003 dodge dakota. 4.7l. I get codes p0685 and p0688. No start no spark. Relay is good. But voltage drops when using a voltage meter on one of the grounds in the pdc. Any live wire and that ground...
Symptoms - Engine Light ON (or Service Engine Soon Warning Light)
Possible causes - ASD relay circuit is open or shorted
- Failed ECM
Tech notes Check all the ECM fuses, if the fuses are OK try replacing the ASD relay. P0685 DODGE Description Short or open in Auto Shutdown (ASD) relay circuit
P0688 DODGE - Auto Shutdown Relay Control Circuit Low
- Failed ECM
Tech notes Check all the ECM fuses, if the fuses are OK try replacing the ASD relay. P0688 DODGE Description The Front Control Module (FCM) has detected the supply voltage below an acceptable value
My 91 jeep wrangler 4.0 will shut down all power at all speeds from idle to driving on the interstate. I jumped out the auto shutdown relay and it works fine but i cannot find the auto shutdown switch to...
There is no switch. The relay gets a signal from the computer. If there is no signal from the crank position sensor the computer will not close the relay. If it runs with the relay bypassed, chances are good that the relay itself is bad.
I have set the auto shutdown to maximum, however, the projector keeps shutting after 20 minutes. What is causing this?
Check to make sure that the auto shutdown is turned off. This should prevent any further problems.
Location of Auto ShutDown Relay for 1989 Jeep Cherokee
Auto shutdown relay and fuel pump relay are by the battery under a cover.
Top MSI Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Sean Wright
Sean Wright
Are you a MSI Computer and Internet Expert? Answer questions, earn points and help others
