P0685 DODGE - Auto Shutdown Relay Control Circuit Failure
Symptoms
- Engine Light ON (or Service Engine Soon Warning Light)
Possible causes
- ASD relay circuit is open or shorted
- Failed Auto Shutdown relay
- Failed ECM
Tech notes
Check all the ECM fuses, if the fuses are OK try replacing the ASD relay.
P0685 DODGE Description
Short or open in Auto Shutdown (ASD) relay circuit
P0688 DODGE - Auto Shutdown Relay Control Circuit Low
Symptoms
Possible causes
- Failed ECM
Tech notes
P0688 DODGE Description
The Front Control Module (FCM) has detected the supply voltage below an acceptable value
This means the relay may look good, but is shorting or stuck in the open position, thus needs to be replaced.
Its not the relay. Replaced that and it didn't work. That leaves a short. Could it be in the pdc itself. Seems to keep voltage in the wiring harness.
It could be. I would start by grounding the control wire from the ASD relay at the Powertrain Control Module connector. Also try test the ASD relay operation with the ATM tests found in a compatible scan tool. If you can get access to a scanner, you can run an ATM test to see if everything is working. In addition, you can look for other PCM data that causes it not to ground the ASD relay. Check the cam/crank sensor signal and missing or erratic patterns.
Turn the ignition off.Disconnect the PCM harness connector.Disconnect the IPM C4 harness connector. Measure the resistance of the ASD Output circuit between the IPM harnessconnector and the PCM harness connector.Is the resistance below 5.0 ohms?
NOTE: Inspect the ASD Relay fuse located in the IPM. If the ASD Relay fuse is open, repair the cause of the open first before continuing. Inspect the ASD Relay Output circuit for a short to ground for the cause of the open fuse.NOTE: Diagnose P685 - Auto Shutdown Relay Control Circuit first if set along with this DTC.
With the DRBIII, erase the DTC.Attempt to start the engine. If the engine will not start, crank the engine for at least15 seconds. It may be necessary to repeat several times.Does the DTC reset?
Jumped the relay ground. Started right up. But heard a buzzing coming from the idle air control. Could it be bad and the pcm is kicking in the auto shutdown? Or should I still look for a short?
