Computers & Internet Logo
Anonymous Posted on May 16, 2013
Disable auto shutdown
It always auto shutdown, while i try to restart, in the process of Startup Repair, it shutdown again. I can do nothing with it. Please help.
Sanath Kumar V
Level 3:
  • Master 684 Answers
  • Posted on May 16, 2013
Sanath Kumar V
Master
Level 3:
Answers
684
Questions
Helped
165054
Points
1521
Restart the Computer and keep tapping the F8 key till you see the advance boot options, You should be tapping the key as soon as you see the manufactures screen. Once you get the advance boot options -> Select the option which says Disable Automatic Startup on System Failure.
Good Luck!!!
5 Related Answers
Anonymous
  • 2961 Answers
  • Posted on Oct 02, 2007
SOURCE: Always shutdown my IBM ThinkPad A21m 2628 PC Notebook
It must be a processor overheating problem, check the vents are not restricted and if the fan is always on or never comes on because of a faulty temp setting then theres a overheating problem and the processor will shut down before any damage.
Anonymous
  • 317 Answers
  • Posted on Feb 25, 2008
SOURCE: HP NX9010 automatically shutdown
Definitely a software problem, somewhere along the installation process, the data on the CD is being read wrong. Try a different installation disk, and see if this fixes the problem. If not, then it could be that there is either a problem with the CD drive, or the IDE controller for the Hard Drive.
Barry Parks
  • 202 Answers
  • Posted on Apr 28, 2009
SOURCE: Startup Repair Problem
Ok, as you have probably guessed, the hard drive is failing. It probably has some bad sectors. The solution is to replace the hard drive and re-install the OS and all of your applications. Then there is the question of data recovery on the current drive. Do you have access to a computer with internet and a CD burner? If you do, you can go to http://www.puppylinux.org/downloads/official-releases and download ver. 4.2. This will be an iso download. Burn the iso image to a cd. Once that is done you will be able to boot the laptop with the CD. The puppy linux OS will be loaded into RAM. You will be able to access the hard drive and backup your data on a memory stick. Once that is done, replace the hard drive and start the installation process. If you have the recovery CD(s) from Dell, Windows will be redone just as it was when the laptop was new.
Good luck, and please let me know if I can be of any more assistance.
~ Spoem
Anonymous
  • Posted on Jun 03, 2010
SOURCE: Windows error recovery
F5 gets you into the BIOS on the Aspires
atang1
Arthur Tang
  • 734 Answers
  • Posted on Mar 04, 2012
SOURCE: my acer aspire 4741G , doesn't start up, it always goes to start-up repair, but it takes long for that process, then when it finaly finishes it still goes back to start-up repair, it it still...
Older Acer laptops use alt-F10. Newer Acer laptops use F11 to reset to factory operating system by hidden partition faster than restore cd..
Toshiba laptop restarting
The loop on your Toshiba Satellite laptop refers to the computer not booting properly.
During the loop, the computer will try to boot the Windows operating system and keep restarting over and over again.
This is not a hardware issue with your Toshiba Satellite A106.
The issue resides in the startup files on your computer's hard drive.
You can fix this by running a repair tool that comes with your Windows operating system.
This repair tool will fix your startup disk and allow you to get your computer back up and running.
Insert your Windows 7 installation disc into your computer's optical drive.
Start your computer and wait for it to boot from the install disc.
Choose your language from the menu and then click the "Next" button.
Click "Repair your computer" from the menu.
Choose the operating system you are using and then click the "Next" button.
Click on the "Disable Automatic Restart On System Failure" button to disable the startup loop.
Click the "Startup Repair" tool from the menu and wait for the computer to fix your startup disk.
Wait for the computer to finish repairing your startup disk and then allow it to restart automatically.
Wait for the computer to boot correctly to your login screen.
Hope this helps
How to Create a Windows 7 System Repair Disc:
http://www.sevenforums.com/tutorials/2083-system-repair-disc-create.html
"This will show you how to create a Windows 7 system repair disc to use to boot to the system recovery options if you don't have a Windows installation disc, can't find your
Windows installation disc, or can't access the recovery options provided by your computer manufacturer."
or
If you do not have access to either disc: Windows 7 - Repair Disc download
http://neosmart.net/blog/2009/windows-7-system-repair-discs/
Launch start up repair
Im not sure if you are wanting to get to start-up repair or trying to get rid of it
If you want to access it, Boot system and do a hard nshut down. Restart, you will have the option to Launch start up repair or to start windows normally
If you are getting the option screen unwanted, this is primarily due to improper shutdown.
Whenever you shut down always try to use shutdown, restart options in taskbar.
If in the event you are stuck and need to do a hard shutdown try pressing Ctrl/Alt/del simultaneously
to access task manager.
Here you can end processes hung up or do a proper shutdown
Restart at shutdown
This behavior may occur if Windows stops responding during a typical operation or during the shutdown process. By default, the computer is configured to automatically restart when Windows stops responding. To view this setting, follow these steps:
  1. Click the Start button, right-click My Computer, click Properties, click the Advanced tab, and then click Settings under Startup and Recovery.
  2. Under System Failure, view the Automatically restart check box. If the Automatically restart check box is selected, Windows automatically restarts if the computer stops unexpectedly.
I can give you anotther solution too
Thanks
Xeeshan
Can,t get beyond the "welcome"
1 try to boot in safe mode once you get to desktop
2 in run type msconfig
3 disable all startup program and restart system
4 if it boots normally then again go to msconfig and select one startup program
5 restart if it start again normally then repeat the last process and keep repeating until you get to the faulty program...
1helpful
My Memeo Auto-Backup does not start automatically with the PC. I have to go to START/ALL PROGRAMS to get it to load. It's been working fine for a couple of years, now suddenly it wont load automatically
Hi there!
The process for that application might have been removed from or disabled in the MSCONFIG startup file. To edit this, click Start>Run>Type: msconfig.
In the Startup tab, search for a process that is similar to or resembles the title of the application. You can also search by using the Command column by looking for the program folder the startup file is located in. Each entry will have it's corresponding company name in the path displayed. In this case that would be Memeo.
If that process is unchecked, check it and perform the same process within the Services tab - if the process has been disabled, the startup properties don't apply.
Click OK and you will be presented with the option to Restart or Exit Without Restart. To view the results immediately, restart and observe the behavior of the boot process. If the Auto-Backup doesn't load like it should, look in the Preferences section of the application and make sure "Launch application during boot" (or similar) is selected. Then restart once more to see what happens.
If the application still doesn't load, you may need to uninstall it and reinstall.
Hope this helps! Good luck!
When i select shutdown computer it doesn't sitch off it restart again
Thanks for using FixYa.
You need to disable the Startup items from the MSCONFIG.
Start the PC and in the Desktop
Go to
1. Click Start --> Run --> Type MSCONFIG --> Click OK
2. On the General tab, choose Selective Startup
Uncheck the program running and click apply. then try to shut down.
Let me know the result, I will further investigate and fix the problem.
Best of Luck & Have a Nice Day
Puneet
Shutdown
Manual steps to perform a clean boot in Windows XP
Step 1: Start the System Configuration Utility
Click Start, click Run, type msconfig, and then click OK.
The System Configuration Utility dialog box appears.
Step 2: Configure selective startup options
1. In the System Configuration Utility dialog box, click the General tab, and then click Selective Startup.
2. Click to clear the Process SYSTEM.INI File check box.
3. Click to clear the Process WIN.INI File check box.
4. Click to clear the Load Startup Items check box.
5. Click the Services tab.
6. (VERY IMPORTANT DON'T MISS THIS) Click to select the Hide All Microsoft Services check box.
7. Click Disable All, then Click on the startup tab and click on Disable All Button and then click OK..
8. When you are prompted, click Restart to restart the computer.
Step 3: Log on to Windows
1. Log on to Windows.
2. When you receive the following message, click to select the Don't show this message or launch the System Configuration Utility when Windows start check box, and then click OK:
You have used the System Configuration Utility to make changes to the way Windows starts.
The System Configuration Utility is currently in Diagnostic or Selective Startup mode, causing this message to be displayed and the utility to run every time Windows starts.
Choose the Normal Startup mode on the General tab to start Windows normally and undo the changes you made using the System Configuration Utility.
Step 4: Optional step to disable features
This step temporarily disables Microsoft features such as Plug and Play, networking, event logging, and error reporting. Also, this step permanently removes the restore points from the computer. The System Restore feature uses restore points to restore your computer to an earlier state. If you remove the restore points, you can no longer restore Windows to an earlier state.
1. Click Start, click Run, type msconfig, and then click OK.
2. Click the General tab, click to clear the Load System Services check box, and then click OK.
3. When you are prompted, click Restart to restart the computer.
Steps to configure Windows to use a Normal startup state
2. Click the General tab, click Normal Startup - load all device drivers and services, and then click OK.
Shutdown problems
boot your pc then follow the steps
start-run-msonfig(type in run command box then hit enter) in msconfig dialog box go to startup-disable all then click apply then click ok reboot,it will take some to reboot, then a message come just clik ok.
when your pc reboot again you restart now you check if the problem is solved
if you want any help fell free to post
Disabling auto restart in windows xp
JUST FOLLOW THESE METHODS
Right-click My Computer, and then click Properties.
2.
Click the Advanced tab.
3.
Under Startup and Recovery, click Settings to open the Startup and Recovery dialog box.
4.
Clear the Automatically restart check box, and click OK the necessary number of times.
5.
Restart your computer for the settings to take effect.
HOPE SO YOUR PROBLEM SOLVES BY THIS SOLUTION
1helpful
Top Toshiba Computers & Internet Experts
ExpressFiX
ExpressFiX
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
