Televison & Video Logo
A
Anonymous Posted on Jan 01, 2014
Volume buttons not working - Denon Televison & Video
1helpful
DNX7120 issue with VOL increase button. When this button is pressed once, the volume skyrockets to max, VOL decrease button does not work right away to lower the volume, nor does the ATT button. Unit...
I had the same issue. You can use the on screen volume buttons on screen to stop issue and don't use the physical buttons anymore. Watch out about a month after the volume problem started all physical buttons on my DXN7120 stopped working. There are a few reports of this online, I have not found a fix yet.
11helpful
W902 Sony Ericsson. My Walkman button and my volume up wont work properly.. i'we already opened up the phone and cant seem to find any damage or visible faulties on the buttons. They seem unharmed and they...
Seems like a known issue with the W902. Same here, dropped my w902 a few months back and the Walkman button and Volume up keys not workin now.
Walkman button not really an issue as you still can navigate to it via the menu system but no volume UP key is annoying. You can't increase volume especially when you volume it down. Power the w902 down and up, will reset volume to 6/10.
Solution: I came across a site where you can change volume without the volume up key.
1. Ensure you lock the phone (* and Contact key)
2. While holding down the disconnect button (the one that you switch the phone off) and camera button (on the right side, bottom button), pressing 7 will decrease volume while * key will increase volume.
You need to hold both button for 7 and * to work. Works great for me as I dont have to replace my phone, hope this help.
Ronnie
4helpful
2answers
Keypad not working v9 moto
The volume buttons on the side of the phone are sticking. My up volume button seemed fine, but someone told me to keep pushing it and the button will release. Sure enough, the volume controls started to work. I played with both the up and down buttons some more and the button below started working. A few more minutes monkeying around with the volume buttons and now all the buttons work.
1helpful
The volume button to the right is not working -
my 8350 volume down button was not working well untill i put a little pressure on the back near the speaker . the volume worked. don't know why but it works.
2helpful
2answers
Dell M60 volume buttons
At the left of your power button, past the word PRECISION, there is a slot for a screwdriver. With the screen fully open, use that slot to remove the power and volume buttons. At the other end of the stip you removed will be the connector that connects the buttons to the motherboard. Reconnect it better. I had this problem too.
1helpful
Volume won't go up
CAMBIALE EL IC02 EEPROM 24C02 O EL 24C04 Y TE GARANTIZO QUE SALDRAS DE ESE PROBLEMA...
12helpful
3answers
Nokia volume
Hi.  I had a similar problem but only the down volume buttonw worked (which meant that my volume was at 1 but I couldn't get it to go any higher).  If you are able to use one of the volume buttons, press it once to take you to the voulme control screen; then use the centre button to conrol up and down using left and right.
Jun 27, 2008 • Cell Phones
1helpful
5answers
Motorola H700 Volume 'Up' Orientation
There is a way to change the orientation of the earpiece and volume buttons. Guest's comment was uncalled for. Suppose you are deaf in the ear that it comes set up for?
157helpful
13answers
How to turn up the volume
i went to settings, then My shortcuts and changed the left selection key to Volume. Then i exited out the main menu, selected Volume, then set it to Maximum. Theni went back and set it to Alarm like before.
This worked fine and now its loud!
Hope it helps.............
Sep 26, 2007 • Cell Phones
Top Denon Televison & Video Experts
 Grubhead
Grubhead
ADMIN Andrew
ADMIN Andrew
Are you a Denon Televison and Video Expert? Answer questions, earn points and help others
