Denon DVD-2910 will play SACDs like a champ. When I load a DVD or a CD, it scans several times and...
(More)
Denon DVD-2910 will play SACDs like a champ. When I load a DVD or a CD, it scans several times and comes up with a display of 00:00.
My DVD291 was modified by PatsConnection in Canada for better 2 ch. audio quality....I just upgraded...
(More)
My DVD291 was modified by PatsConnection in Canada for better 2 ch. audio quality....I just upgraded TV to HDMI compatible (from DVI).
My problem is that even after resetting to factory specs - via code from Denon...no video.. I run player to stereo (2ch) integrated amp, so I get audio signal, just no video.
Question: is it possible that during mod - the HDMI input was disconnected and not re-connected?
Is this something I could remedy fairly easily?
Many thanks for any guidance!
-Steve
I just get a used denon dvd-2910 and it just plays fine with cd, dvd. however when I stop play...
(More)
I just get a used denon dvd-2910 and it just plays fine with cd, dvd. however when I stop play and want to power off using the remote, it does not do. On the tv screen, it show an icon, that I under stand can not power off. If i use the power on/off on the dvd unit, this will be ok. Is my dvd unit wrong or .... Thank you for all hints.
My player has worked fine for 2 years. I went to play a dvd and it's locked up. Display shows...
(More)
My player has worked fine for 2 years. I went to play a dvd and it's locked up. Display shows '2910', and no buttons work including drawer open or standby. Remote doesn't work either. Tried factory reset in tech manual. Power was plugged into Denon receiver and receiver was plugged into excellent surge protector...so almost positive no electrical surge went to player. Is there another master reset for unit. Thanks.
My DVD player a region code free modified Denon DVD 2930ci(not listed in the product line below) is...
(More)
My DVD player a region code free modified Denon DVD 2930ci(not listed in the product line below) is having problems playing my discs, mostly audio CDs which is what I play most often maybe 90 percent of the time, while watching the occasional movie maybe a couple of times a month or so, generally without issue.
I do not believe that the CDs themselves are the problem as they are generally scratch free and in good condition. Some discs are virtually brand new, having been played maybe twice, but they too have problems when I try to play them. When I first put a CD in the DVD player's disc tray and close it, the player says "Loading" seems to "scan" the disc I surmise then displays the discs summary info of tracks and total duration. When I press "play" the player usually works fine playing the disc from the beginning and I can enjoy my music, but after finising track 1 and 2 let's say and then skipping to track nine the music won't play. The disc just seems to spin and spin as it seems like the player is struggling to read the disc. There are some audible clicking and less noticably screeching sounds while this happens which is why I say the player is trying to and "struggling" to read the disc. But then, if I skip ahead to the next track, 10, which also doesn't play doing the same thing, and then go back to the previous, track 9 sometimes, often it will play to my surprise and delight. I have had this and similar disc reading problems for maybe the past year, but now it seems to be happening more frequently and regularly.
I suspect the lens, or laser assembly(the part that reads the disc) but this is just a guess and I don't really know all that much about electronics or DVD players, in spite of having read a few books and hope that somebody can help me with this problem because it has become quite frustrating leading me to consider purchasing another player. The only problem is that I have had this player for only about two years now, and while I bought it off of eBay because I got a fantastic deal on a high-end player, I was expecting it to last for a while giving me great joy with it use as a long term investment, given it's high quality performance and build. I would also like to say that upon receiving my player from the seller off of eBay, yes it was used, but appeared to be in very good condition and it did not give me any problems, at least initially.
My DENON2910 from 2 days, is freezing the image constantly and repetitiveli at 2 to 3 seconds in...
(More)
My DENON2910 from 2 days, is freezing the image constantly and repetitiveli at 2 to 3 seconds in Video COmponent. In HDMI the image is istil freezing, but adicionaly is presenting some kind off interference, lije an horizontal color bar displayed at 2 to 3 seconds. I still did a firmware update, but the problems continues. How can I solve this?
When you get no disk error, that is usually because of a problem with the
optical laser lens that is dirty, faulty or opaque, and will...
written by ginko
To reset the recorder to factory defaults as if it was just removed from the box - leave the recorder on then press and hold the channel up and down...
written by xmarine2847
You can help other;s and maybe they will help you. This can be done by uploading a copy of you user manual and any service information for the...
written by stoneheaded
My LG DVD recorder was unreliable when recording TV broadcasts to "standard" DVD disks. Frequently it would begin recording a show and then...
written by MateusDIY
You should always read the owners manual to familiarize, yourself with the operations of the unit. This will solve a lot of simple operation problems...
1)just open the player 2)remove the rubber belt connecting the dc motor 3)you
can open the disc tray now 4)if there are any dust particles or...
written by dileep007
It is always suggested that you use or buy a cd or dvd cleaner with it's cleaning solution, but I have discovered something that works just as well if...
written by BobbyR1234
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC EQU... Read More
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC EQUIPMENT, TECHNICAL CONSULTATION, REPLACEMENT OF LAMPS IN LCD AND DLP PROJECTION TELEVISIONS.
QUALITY SERVICE AND REASONABLE PRICES.
HDCD · CD-RW · CD-R · CD (Audio) · DVD Audio · VCD · Picture CD · DVD-RW · DVD Video · DVD+RW · DVD+R · DVD-R · SACD
Playable File Formats
JPEG · WMA · MP3
Video
Picture Control
Zoom
Video Output System
NTSC · PAL
Video DAC
12 bit / 216 MHz
Video S/N Ratio
118 dB
Audio
Surround Sound
Built-In Dolby Digital Decoder · Built-In DTS Decoder
Audio DAC
24 bit / 192 kHz
Dynamic Range
106 dB (DVD) / 106 dB (Audio CD)
Audio S/N Ratio
118 dB
Connections
Outputs
Composite x 1, S-Video x 1, Component x 1, DVI with HDCP x 1, HDMI x 1, Analog Audio x 1, Analog Surround x 1, Digital Audio Coaxial x 1, Digital Audio Optical x 1
