20 Most Recent
Denon RC-8000 LCD Touchscreen Remote Control Questions & Answers
My remote control rc-8000 niva is not operating
Check the remote control for its infrared emission. Check it with fresh batteries. If you wish to get more details about how to check a remote control, check the site linked here.
Pull up previous posts by its left sidebar, or type in the
brand name and model number to of your set, to its search box, and
press '
Enter' or view it in
Mosaic / Timeslide
option.
I need to replace the
Hello
Nickel-Cadmium battery will have a voltage of 1.2V. Four cells together with in series connection give you 4.8VDC, The number 8000 on Denon battery denotes, that it has a current rating of 8000ma [milliampere]. Most of the Ni-Cd batterys will have the same rating. You can use any company's prodcut, provided the size should be the same. That is all. Some battery packs will have 1 ampere capacity, can be used in place safely. No problem at all. OK.
Accidentally deleted setup menu and can't restore it.
Dear dalton....Patrick here
I believe this may be impossible with normal use. Alarge magnictic force would do this. My RC-8000 had odd ball problems that it was sharing with my 5803. Once I fixed the JOY STICK all other problems went away. If it has programing issues, then Denon will have to deal with it. Use there Portland Ore. Service Center and Pay the money.
Patrick
The only screen I get is5/1 nothing else
Dear granggreen....Patrick here....
Even if you have performed these functions I want you to do them again. Remove the battery cover, remove the re-chargeable battery and it's blocks that hold it in position. Install new AA batterys, press the RE-SET BUTTON and hold for three seconds. If these steps prove nothing my instinks say that one or all Joy Stick discs are flat. Surgery is needed.
Patrick
Found an RC 8000 on ebay with a buy it now!
Doug_ie1
Patrick here....aske the seller if the rechargeable battery and AA battery blocks are still withe the RC- 8000. In writing from the seller have them clarify that the joy stick/ selector works. Pay no mre than $125.00 if the RC-8000 is perfect.
Patrick
I need to fix the ENTER button.. I've removed the
To fix this problem with the malfunctioning " Joy Stick", and or selection or enter button, you must seperate the Remotes halves. There are no springs or other parts that will come flying out when the halves are split. Do Not use a screw driver to separate the seams the best tool is a tool used by manicurist on cuticles or make your own. Squeeze the bottom half while moving along the seam. Once you have two of the plastic catches released, the others will come apart. Then remove the three philips screws that will allow you to remove the board and attached LCD screen. The LCD screen is attached with a ribbon cable. To remove this cable, first back off the cable pressure locks! What looks like the end of the cable is only a pressure lock and stays with the main board. Do Not get in a hurry with this ribbon cable! Use a magnifying glass to have a close look! Turn the board over and remove the " button boot", this will allow access to the joy stick. The joy stick button is a friction fit and can be removed with equal upward pressure. Now you are at , what is a five way switch. Study the switch with your magnifying glass and a good light, you will see how the metal bracket holds the switch together. Bend the catches back on only one side of the bracket. This will allow you to remove the joy stick and see the five small concave metal discs. These discs are tempered to make contact and return to there concave shape. The center disc on mine was not concave, but near flat. These small parts will want to get lost!! Move slowly! I removed the middle disc and used a gold plated RCA plug that was rounded just enough to match the concave design of the disc. A few light taps and the disc conformed to operational shape. Putting the small disc back into the switch was testy. Reassemble the unit slowly, pay attention to the RF antenna, you do not want to break the solder connections. Clean the LCD and be sure you have the ribbon cable seated all the way into it's clip.
My RC-8000 now works and fixing this pesky switch cleared up a few other odd things going on in my 5803.
Patrick J Horan
Denon 687 ,,,,red light is on then I push the power button and it blinks green and their stays green but no display at all nothing else lights up
Considering you have a standby light we know the hot side of the power board is working, next step is test the power on signal coming from the main board, it should be marked on the legend on the power board what pin is power on, will be marked PO_ ON PWR or something like that, you need at least 3 vdc there when you turn the set on, if it's missing replace the main board, if you see voltage replace the power board, easy simple fix with only one measurement, verses guessing what board is bad. Sorry you didn't get any other useful help, there are some posters on here giving non helpful generic help anyone would know to try
Completely clueless on setting up Denon 1709 AVR
Yes, you can still use the speakers even if they are not currently connected to a TV. To connect the speakers to your computer, you will need an audio cable with 3.5mm plugs on both ends. One end will plug into the headphone jack on your computer, and the other end will plug into the input on the speakers. Some speakers may also have RCA input, in which case you will need an RCA-to-3.5mm audio cable.
If you have a newer computer with only a digital output (such as a USB-C port), you may need to use an audio interface or a digital-to-analog converter (DAC) to convert the digital signal to analog so you can plug it into your speakers.
Once the speakers are connected to your computer, you can adjust the volume using the volume controls on your computer or the speakers themselves. It's important to note that your TV will not be able to use the speakers unless they are connected to it.
