Question about Motorola Mobility H700 Wireless Headset
Motorola H700 Volume 'Up' Orientation
Hi. I've noticed that the volume up key on my H700 is the lower button. I tried changing it to have the top button as the volume up key. I followed the user guide to change this but it doesn't work. How do I change this, please?
Posted by g1zm0 on
  • Anonymous Jul 21, 2008
    im left handed so the volume keys are reversed.
    can't seem to flip them........tell me how!!!
    tried presing both volume keys together......nothing.
    tried on paring mode.......nothing.
  • Anonymous Mar 16, 2014
    manual
PCG_PREZ
There is a way to change the orientation of the earpiece and volume buttons. Guest's comment was uncalled for. Suppose you are deaf in the ear that it comes set up for?
Posted on Nov 04, 2007
Anonymous
I too was going annoyed by this.
Turn the headset power off by closing
the headset boom.
Press the Call button until the
indicator light becomes steadily lit in
purple, then press the Volume button
you want to assign as the "volume up"
button MULTIPLE TIMES until the indicator light turns off.
This method worked for me and I hope it will work for others.
-nubian
Posted on Mar 23, 2008
Anonymous
the headset boom.
button.
Posted on Mar 20, 2008
Anonymous
I tried the same thing. Switched the H700 to my left ear and can't change the "up" volume to the top button.
Posted on Feb 18, 2008
Anonymous
Put the thing on your other ear - you have it upside down knucklehead.
Posted on Nov 02, 2007
I have a Motorola aur12000 Cordless Phone and it does not ring loud.
Hi debora maisonave!
To modify the volume level on your phone please follow this steps:
To raise the volume:
  • During a call: press the key up to raise the volume of the call.
  • When the phone is ringing: Press the key up to raise the volume of the ringtone.
To lower the volume:
  • During a call: Press the key down to lower the volume of the call.
  • When the phone is ringing: press the key down to lower the volume of the ringtone.
Hope these steps help!
Regards
Gaby
Motorola Customer Care.
Feb 11, 2015 | Motorola Mobility Dect60 Cordless W...
Where is the volume
Little buttons on side of headset. Typically the factory setting is for right ear. So volume button on top would be up volume and bottom would be lower volume.
Mark
Motorola Support
May 20, 2014 | Motorola Mobility H371 Bluetooth Headset
My hands free is on mute and won't come off mute .
Hi, Motorola H700 Wireless Headset does not go on mute, it might be from the volume control of the Motorola H700 Wireless Headset or from the cell phone volume control.
You can use this quick guide to know how to increase and decrease the volume control.
motorola.com/mdirect/manuals/QG-H700_9499A88O.pdf
Hope it helped.
Have a nice day.
Mar 01, 2011 | Motorola Mobility H700 Wireless Headset
How do I adjust the volume so that a listener can hear me better
Hi
Volume button is shown in below image IHighlighted)
You need to assign the volume button that is which one is down and which one is up button
1.Turn the headset power off.
2.Press the Call button until the indicator
light becomes steadily lit in purple, then
press the Volume button you want to
assign as the "volume up" button.
Thank You
Sep 02, 2010 | Motorola Mobility H700 Wireless Headset
How do I turn up the volume?
The volume keys are the silver keys on the top and bottom. Simply push the volume up button to adjust the volume If you are not sure which button is volume up, or simply want to change which is which, you can change the button orientation.
Here's how:
-Close the boom to turn the headset off.
-Press and hold down the desired "volume up" button and open the boom. Keep the button pressed until the indicator light flashes blue three times.
If you just want to see the user's manual it's here...MANUAL
Aug 18, 2010 | Motorola Mobility H710 Bluetooth Headset
Hearing from Motorola H700
good morning!! ive been thru this before, try tapping your phone volume while your talking to your party, it shold be seen on your phone screen as earpiece volume than turn it up and when you have the volume where you want it dont forget to tap the set on your phone, another prob i had was some times there is a small protective plastic film on the ear holes on the tooth and one on the mike sometimes, i could hear my party but they couldnt hear me until i discovered that lil peice of plastic. remember your key codes are either 0000 or 1234. good luck m.m.
Jan 26, 2009 | Motorola Mobility H700 Wireless Headset
Earpiece volume on my motorola h700 is low.
while talking to your party try the volume on your phone, it should come up as bluetooth or earpiece volume if it does just turn it up and dont forget to hit the set button. good luck m.m. p.s. some times the volume isnt set at the factory. im fighting that problem now on two of my seven h-700s. this may be a solution it may not im letting you know my experiance as best as i can.m.m.
Jan 22, 2009 | Motorola Mobility H700 Wireless Headset
Blinking Indicator Light When in use
press the volume up and volume down keys at the same time and hold them until the light quites blinking you have to do this every time you turn your headset on
Sep 05, 2008 | Motorola Mobility H700 Wireless Headset
MY H700 MUTE BUTTON HOW TO GET IT OFF MUTE
Where are the solutions for these problems? I don't see a fix for anything on fixya. What gives?
Dec 27, 2007 | Motorola Mobility H700 Wireless Headset
Problem with Motorola H700 Bluetooth
rhondarenee: If you're using a Motorola RAZR V3, the problem is the cell phone. Also check the volume buttons on H700 that sometimes it goes the volume all the way down. It is a common unnoticed situation. SithPitt
Jul 04, 2007 | Motorola Mobility H700 Wireless Headset
Motorola Mobility H700 Wireless Headset Logo
639 people viewed this question
Top Motorola Mobility Radio Communications Experts
Lawrence Oravetz
Dennis
Are you a Motorola Mobility Radio Communication Expert? Answer questions, earn points and help others
