Check mechanism on working doors. In my car if I move the catch on the door(click it like in closed position)like it was closed,then when I open the handle it releases open;this shows me closing/opening. Spray penetrating fluid on the metal/mechanism,possibly rusty and prevents smooth actions. Hope this helps.
I have a 2005 Xterra and the same thing started happening to me on an intermitent basis. The dealership eventually replaced the guts of the door release equipment under warrenty but that was after 3 trips to the dealership.
Now my rear hatch won't open. My theory is that after an total repaint (hail) in the summer of 2006 the body shop made something out of wack with these door mechanisms.
Mine was doing the same thing. I took it in and watched them fix it and first they steam cleaned the area under the floor where the rollers are. Then they took a spray and lubricated the rollers and the track where the rollers are. then they cleaned the brass connectors on the side of the door where the safety pins touch. I could have saved ALOT of money doing this myself. I hope this helps!
It is likely the window motor is wearing out and will need to be replaced. You can always try a different switch on those wires to rule out switch problem. Otherwise, the motor will have to be replaced.
go inside, lift on handle, then beat the **** out of the door pounding it like your trapped in it trying to get out. latch mechanism is probably corroded and froze shut. once open, spray with wd40 and work the lever a lot. then get door panel off to see if handle is broken inside
Try an obvious thing first. Check the actual runner channels on the body of the vehicle aren't full of dirt and rubbish. I've been caught out by silly stuff like that!
This sounds like it might be an issue with the 'Automatic' part of the door. Does the Auto close still work? Something might have come loose inside the mechanism and is blocking the doors movement.
If the door was off it's tracks the door wouldn't sit right when closed and you would have trouble locking it. The door would look either twisted, where the door gap is wider at one end than the other, or it would sit further out at the top or bottom as you look down the side of the vehicle, where it's jumped out of its runners.
Door latch on door itself is in closed position if it will not close at all. In this case, open door and pull outside handle hard to pop open door latch. If you have door opening at random, door latch needs replacing or door catch on body is loose.
IF DOOR WONT OPEN FROM INSIDE THEN IF YOU LIVE UP NORTH RUST IS PROBLEM.....TAKE A FUNNEL POUR BRAKE FLUID WHERE THE LATCH IS....WAIT 1-2 DAYS AND DOOR WILL OPEN.....SHORT TERM FIX
The proper way would be to look at a wiring diagram an test the electrical circuit's with a DVOM - digital volt ohm meter . Do you know how to test automotive electrical circuit's ? Electric Testing Techniques You Need to Know The Trainer 32 How To Read An Automotive Block Wiring Diagram
Free wiring diagrams here http://www.bbbind.com/free_tsb.html
Enter the vehicle info. year , make model and engine size . Under system click on body & accessories ,then under subsystem click on power sliding door . Click the search button then the blue link. Looking at the diagram you will see a control module is used .
Also reading factory service info. on how it works would be a good idea.
Rear Side Door Actuator Control Module
The rear side door actuator control module is capable of on-board diagnostic functions described in On-Board Diagnostic Features . The rear side door actuator control module monitors the door position at all times including during manual operation. After activating the on-board diagnostic modes, loosing battery voltage, or ground to the rear side door actuator control module the Power Sliding Door (PSD) Re-Initialization procedure must be performed in order for the rear side door actuator control module to correctly determine the door position.
Power Sliding Door System Description
The power sliding door system(s) can operate correctly only if the power sliding door is in proper mechanical condition. Any mechanical problems will affect the power sliding door operation and must be repaired before attempting to diagnose the power sliding door system. Manually open and close the power sliding door to determine if the door moves smoothly and without excessive resistance or binding. The power sliding door must also latch and unlatch without the use of excessive force. At any time during power sliding door open or close operation, excessive resistance to the door movement will cause the power sliding door to stop and reverse the direction of travel.
The power sliding door will operate only when the power sliding door on/off switch in the overhead console is in the on position. At anytime during power sliding door operation the on/off switch may be turned to the off position and the system will quit any function in process. The power sliding door will not open unless the transmission shift lever is in the park position and the door is unlocked. When the sliding door security lock is in the locked position the power sliding door will not open from the inside. The power sliding door close function will operate when the vehicle is in gear. The power sliding door module uses the VSS signal to determine if the vehicle is moving during a power sliding door close function. The momentum of the vehicle moving forward adds resistance to the door closing operation. When the rear side door actuator control module determines the vehicle is moving forward while closing the door, current flow through the actuator motor is increased instead of being reversed. The VSS signal circuit is supplied battery positive voltage through a resistor then monitored within the rear side door actuator control module. The VSS signal circuit is then pulsed to ground, or pulled low by the powertrain control module in relation to vehicle speed. The sliding door alarm will sound repeated short tones whenever the power sliding door system is turned on and the door is open while the transmission is out of park.
When the power sliding door system is on and manual operation of the power sliding door is detected the rear side door actuator control module activates the power assist feature. When the power assist is activated the power sliding door will continue to open or close without any further manual effort.
The power sliding doors may be operated using the Remote Keyless Entry System. The keyless entry transmitter will have one OPEN/CLOSE button with a van symbol on it for each power sliding door. The power sliding door ON/OFF switches in the overhead console must be in the ON position in order to operate the power sliding doors using the keyless entry transmitter. When a right hand power sliding door OPEN/CLOSE function is activated using a keyless entry transmitter the exterior lights will flash once indicating the RKE module has received the OPEN/CLOSE command. When activating a left hand power sliding door OPEN/CLOSE function with the keyless entry transmitter the exterior lights will not flash.
The left and right power sliding door systems operate as independent systems. The on-board diagnostic modes are entered and operate the same in both systems.
The power sliding door systems are capable of the following on-board diagnostic functions:
• Diagnostic Mode 1: An audible signal indicates the diagnostic trouble codes stored by the rear side door actuator control module.
• Diagnostic Mode 2: An audible signal indicates when inputs to the rear side door actuator control module are active.
• Diagnostic Mode 3: Performs an output test of the sliding door unlatch actuator.
Entering On-Board Diagnostics
The on-board diagnostic modes can only be entered in a sequential order from modes 1-3.
• Enter the right power sliding door system on-board diagnostics using the right B-pillar open/close switch and the right on/off switch in the overhead console.
• Enter the left power sliding door system on-board diagnostics using the left B-pillar open/close switch and the left on/off switch in the overhead console.
1. Both power sliding doors must be closed and in the latched position.
2. Place the ignition switch in the OFF position.
3. Place the on/off switch in the overhead console to the OFF position.
4. Press and hold the B-pillar power sliding door open/close switch.
5. While holding the open/close switch, operate the on/off switch through 10 ON and OFF cycles within 10 seconds stopping in the on position.
6. The sliding door alarm will sound 1 long tone indicating diagnostic mode 1 is active.
Diagnostic Mode 1
Upon activating diagnostic mode 1, DTCs will begin to be signaled by the sliding door alarm. The DTCs are 2 digit codes and the codes are represented by the number of buzzes for each digit of the code number. For example a DTC 12 is represented with the following sequence: buzz, pause, buzz, buzz, long pause. Each DTC will be signaled 3 times before proceeding to the next DTC. Refer to Diagnostic Trouble Code (DTC) List . The DTCs will continue to be repeated in this manner until the on-board diagnostics are exited or mode 2 is entered. When exiting the on-board diagnostics all stored DTCs will be erased from the rear side door actuator control module memory.
check the closing mechanism and see if it isnt locked down in the closed position, if it is stick your finger in there and pull it out like it would open while moving the door handle, if thats not the problem, see if there isnt a toy or something stuck in the tracks on the bottom or dirt and leaves on the top
Look on the end of the door and you will see the slot where the door catch is located. It should line up with a big stud sticking out from the post by the drivers seat. The gap should be open. If you see a piece of steel blocking the slot, then the door catch is already in the latched position. Insert a screwdriver into the bottom of that catch and pull it up into the open position. If that is the problem, the door will work after that. Hope that helps
I have seen some times the latch assemblys get rusty or dirty and the inside or outside door handles are pulled and the latch assembly siezes in the open position not allowing the door to latch closed..but this may not be the case .. check to see also if the child lock switch position is not stuck in the halfway position, also check if the latch has not flipped to the close position before the door was closed thus jamming the striker latch..this can be fixed by pulling the catch out while opening the door handle..hope this helps good luck...
If latch is closed, as in 2 fingers are wrapped around closing spot for door pin to catch, use a screwdriver or similar and slide through hole between them & pull them open while holding door handle in opening position. Lube up good after.
sounds like the door sensor switch is malfunctioning and when almost closed it reacts like it is blocked (such and kid in way) and opens for safety. try flushing trach with hose and try again, if not u need a good repair manual such as chiltons($25 most parts stores ) or see mechanic
Hold the door handle in the open position while using a bent coat hanger on the door catch lever.Sometimes a flathead screwdriver works to pry the door catch as well. Good luck, keep me posted.
