Help meeeeeee! The display screen jus says"printer error----see your documentation...and call services..." in the documentation it jus says contact your local dealer. help please please
I just fixed the problem .. you have to reset the protection counter FIRST .. then do the reset using the triangle and colour buttons.. this it the link for the SSC utiliity to reset the counter www.ssclg.com/epsone.shtml .. my printer works fine again
The problem is that the paper feeder has popped around .You need to push it ba ck gently . you,ll find it at the back centre where the paper is fed from.It occurs when paper is pulled back out after jamming.
The scanner part of my cx3200 is asking me to call a service engineer. I do know that there is a
way that I can re set it but don't know what it is can you help.
Printed 2 sheets then replaced color ink cartridge. Attempted to print again with horrible grinding noise from printer > error message. Turned printer off and attempted again. Same grinding and error message.
Followed the instruction...turn it off and on with no change.
Okay, so i have the same message and scary sound when trying to print. I agree that it is probably the paper feeder, but it doesn't seem to want to budge and i of course do not want to force it. Should i be pushing it up or down. Is it the little piece with the rubber on it, sort of curved? help!!!!
I have the same problem with the error and loud noise, and it did happen after I pulled out some paper from a paper jam. I need to know what the paper feeder is, and how do I pop it around?
okay, so I think I figured it out, and it doesn't do that loud noise anymore, but now it won' feed the paper into the printer, and the menu says it's out of paper...did I break it?
Was working fine, then Red error light came on Saying , Some perts of my machine had reached the end of their life, Until then it was fine, Now I can't get rid of the Error, Thanks Terry
Following a paper jam, from which the only solution was to pull the paper out backwards, I have been receiving the error message "Printer error --- see your documentation and call service if necessary" I have downladed a service manual and attempted to strip the printer following the excellent guide by Den Conway - thanks Den - but to no avail for on reassembly the same error occurs. I failed, however, to find the "black plastic arm and spring to which Den refers. Must admit that I was a wee bit scared of dismantling too far in case I did more harm than good. If all else fails I'll wait 'til January and try to buy another printer in the sales! NOT an Epson!
I HAD A PAPER JAM AND REMOVED THE PAPER. IT NOW SHOWS PRINTER ERROR AND THE WHITE TAPE FROM BEHIND THE CARTRIDGES IS VERY LOOSE. THE WHITE TAPE IS ALSO LOOSE
UP TOP WHERE I MAKE COPIES FROM. I HAVE TURNED THE PRINTER OFF AND ON SERVAL TIMES. IT MAKES A LOT OF NOISE AND SHOW THE SAME ERROR. THE POSITION OF THE WHITE TAPE DOES NOT CHANGE.
Hi , i have the problem with my epsom cx3200 saying some parts have come to the end of thier life & to see service, but have been advised by an independant person that it will be cheaper to buy a new printer is there no way round this?
Dear Sir/Madam,
a good day to you; but i have got a strange problem with my epson 1400 printer.
I had just aquired this printer a week ago from the UK, & i have used it for about four days, & within these dats, i printed an approximate of 900 copies, but
while i was printing, i got a warning in print dialog box, saying SERVICE NEEDED"parts inside your printer are near the end of their service life, see your printer documentation" & from their i started seeing both the paper button & the ink button flashing red lights, one after another, & the power button not flashing, yet i All this happened when i was using original epson cartriges. So where can i find the software to solve this problem so i can continue with my work. More so, what do you think would be the cause of the problem? and Unable to find epson service center in uganda
I`m gladly waiting for your reply, because i`m totally stranded.
REGARDS
JEFF.
Regards
mellisa
Marvis Suppliers
Plot No. 6 Amir Street
Uganda-kampala
P.O.BOX 33833
i need fix the problem my printer eror documentatien
please snd me program fix
I have this same problem... have tried to reset the eeprom as suggested but still not working.. anyone out there contacted epson tech support yet ??
PRINTER SAYS ERROR SEE YOUR DOCUMENTATION AND CALL SERVICES. I HAVE TRIED RESSETTING COUNTERS WITH SSC EPSOM DOWNLOAD BUT IT DIDN,T FIX THE PROBLEM
screen says Printer error see your documentation and call service if necessary
