Thumping noise as top rack washer bar spins around underneath the top rack tray.
I have a Kenmore Elite dishwasher. During the wash cycle there is a thumping noise. It looks like the wash bar underneath the top rack is hitting in the back of the dishwasher when it spins. There is a plastic circular fitting that goes into a hole and appears to stabilize the top shelf. It appears it is not seating properly.
How do I fix this?
Re: thumping noise as top rack washer bar spins around...
Make sure the connecting tube is seated properly, then use a self tightening plastic strip to secure it to the upper basket..they are available at hardware stores
Jul 27, 2015 - Agitator directional cogs aka "agitator dogs" (top load washers) ... If you hear a rubbing sound or the drum spins uneven, then the ... A washer making a loud noise during spin cycle can also be caused ... The clutch in a washing machine connects the inner wash tub to the ..... May 8, 2015; High Water Bill?
Apr 11, 2014 - Dishwasher Making Loud Grinding Noise During Wash Cycle ... GE, Whirlpool, Frigidaire, KitchenAid, Maytag, Kenmore, and LG) this is a .... Our Amana dishwasher is making a loud, high-pitched squealing noise throughout the wash ....Out Of A Washing Machine - Top Load & Front Load September 30, ...
Did you have an oil leak at the bottom of the washer? If yes, chances are your transmission oil leaked and your transmission needs changing or repairing.
The pump is likely damaged if it was leaking. Look for a ring of melted plastic on the face side of the pump. Check to make sure the hole is not rounded where the motor shaft enters the pump. I'd replace the pump just to make sure the washer doesn't flood some time in the future even if the pump turn out to be ok now.
Most noises from a washing machine occur during
the spin cycle. If you hear loud thumping during the spin, the load of
clothes may have become unbalanced. Stop the washer and redistribute the
clothes, then re-start it. Repeat these steps if necessary.
It's noisyMost noises from a washing machine occur during the spin cycle. If you hear loud thumping during the spin, the load of clothes may have become unbalanced. Stop the washer and redistribute the clothes, then re-start it. Repeat these steps if necessary.
Check the stainless steel cover on the bottom of the lower rack sprayer. If it has been bent downward on either end, it will hit the inside panel of the door near the bottom. It may score the panel as it hits on each rotation of the sprayer.
Just bend it back in position, carefully, with a pair of pliers. The technique required is similar to bending the pocket clip of a fountain pen back into the proper position after it has been sprung out too far. You might practice on a pen or mechanical pencil clip to see what I mean.
Mine is doing the same thing. I opened it up to see what was happening and it was the drive belt tension arm bumping around. Soon, the belt started slipping during the spin cycle. Now it won't spin and the belt starts to smolder from the friction of the drive motor. If you haven't checked your belt, that's a good place to start.
make sure all shipping pins are out the tub should move all around from side to side if it level still bangs its eather the balance ring top basket are there 3 slides on a plate above the motor just put some silacone oil on tham move around
