The pump is likely damaged if it was leaking. Look for a ring of melted plastic on the face side of the pump. Check to make sure the hole is not rounded where the motor shaft enters the pump.
I'd replace the pump just to make sure the washer doesn't flood some time in the future even if the pump turn out to be ok now.
Vlad,
First Choice Appliance Service. Sacramento, CA
SOURCE: Kenmore front loading HE3 makes knocking sounds during spin cycle
Ours started knocking several months ago and then progressed to a high pitched sound when in the spin cycle. I manually turned the drum and heard and felt a bearing roughness. I lifted the drum assembly and felt a fair amount of play, which I think the initial knocking noise came from. On the sears web site a new rear drum mount cost 293.00. Today we went and bought a LG model wm2455hw at Home depot, on sale until 2/20/08. I couldn't see paying to repair a machine that only lasted four years.
SOURCE: Washing machine will not drain/go into spin cycle
Check your lid switch. If the lid switch is not making proper contact, or is broken, the washer will fill, agitate (some model washers won't), then just stop when it gets to the spin cycle. If this is what you are experiencing, then this could be a quick and easy repair for you.
Try opening an closing the lid. If you don't hear a clicking noise when the lid closes, the lid switch may be bad or loose. It is mounted under the opening of the tub rim on the right-hand side and held in place with two screws. Make sure the lid strike ( a small plastic piece) is present on the lid as well. This closes the switch contacts when the lid closes. If the lid switch does not function, the washer will not complete a wash cycle.
If the determine the switch and/or lid strike is broken, searspartsdirect.com carries the parts need. Just type in the model number you provided and you will find the lid switch under the "Top and Cabinet" heading as item #11 (part #3949238). The Lid Strike is under the same heading as item #20 (part #350733).
If you need advice on how to replace the lid switch please post back and let me know.
If I'm off the mark here, please post back with comments and give me a little more elaboration on what your washer is doing or not doing.
PS You do not need to drain the tub to replace the switch. If you wish to drain it, however, and want to by-pass the lid switch, I can give you instructions on how to do this as well.
SOURCE: Kenmore Oasis Washing machine makes noise during Spin cycle
with the machine empty see if you can lift up only the tub and see if it drops down.check to make sure there is nothing between the tub and outer tub have you gotten an f-51 error?
SOURCE: kenmore series 80 washer makes loud knocking noise during spin cy
Unless your front loader is set firmly on concrete
and leveled to perfection, the force of a heavy wash load spinning in
excess of 1000rpm will create a bit of vibration and noise.A firm footing is your best defense against to much movement.
Also due to the earlier movements during the spin cycle, the
shocks that are used to dampen the spin cycle might have been broken or
damaged.
If the problem persists inspite of proper levelling, please do check for the shocks or might have them replaced them for good.
SOURCE: Kenmore 80 Series washing machine - loud banging at end of spin
With the lid open, set the cycle to spin and press the lid switch button with a pen. Wait until the drum gets to full speed and release the lid switch. If the drum makes a knocking/ thumping noise and doesn't stop spinning within 2-3 seconds, the basket drive block is worn and needs to be replaced. (The basket drive block is located on the gearcase drive shaft, under the tub and agitator) If this has been happening for a long time you may need to replace the brake and drive tube assembly as well.
Basket drive block part number is 389140
If that's not it, let me know and I will try to help you further.
It is so common that the drain leaks in many ways and
is the most problematic fault in a washing machine. In all occasions it is
important that your observation is most important and so is vital to the
identification /rectification and solution. If you have noticed that water has
leaked then as the drain hose pump/valve and fittings are located on the
underside of the machine it is important that you look for possible leaks here.
In some cases the drain hose would be clogged at the drain end to outlet of the
house and so there will be back flushing resulting in overflow to the outside.
Also the drain pump/valve can be clogged or the drain hose clamps can be loose
on the grip which can all cause the leak to occur. Removing and cleaning the
drain pump/valve, tightening of the hose is also very important. Also water can
leak if there are gaps on the front door gaskets and must be checked but this
will happen only during the cycle and not on the drain cycle end.
Tips for leak: http://www.espares.co.uk/advice/washing-machines/a/7/1461/do-you-have-a-leaky-washing-machine.html
Check for tips on the link below to identify parts and
removal:
Also check on the SEAL on the door and drum, it can also be worn out and reposition the drum to move out which can result in the noise when the spin is activated.
Thought I better look in the water pump for a blockage and sure enough, found a sock! Haven't put it back together again yet but hoping it didn't cause any other damage.
