SOURCE: BIOS Resetting...
Please open this link this will help you
http://www.thenetworkadministrator.com/biospasswords.htm
And dont forget to rate FIXYA if it didnt help please reply but dont rate any rating
Thanks
Regards
SOURCE: Toshiba satellite A215-S5818 bios password
This should be able to be solved by opening the Ram bay and shorting out two solder points. Usually marked with a "xxx". The notebook should be started with these solder points shorted. Once the pc is on, it should go through the normal process without asking for a bios password. Once the pc is restarted, the CMOS password should disappear.
SOURCE: how to remove bios password for Toshiba Satellite A200
If you know the current password, use it to enter BIOS SETUP.
Then, type a "blank" ("space-bar") as the "new" password.
If you don't know the current password, you're stuck;
this is a "security" feature to prevent a stolen laptop from being used by the thief.
SOURCE: I need the bios reset password for a toshiba laptop
there is no actual password. you need to remove the ram and short out two pins underneath the black plastic they look ike two E's connected like E3. use a flat blade screwe driver. do this while powered off!
SOURCE: Toshiba Satellite Pro A200 BIOS Password Request
for removing the password,
you have to open the memory cover and remove the two RAM s,
after that remove a black or whit plastic film depending on your model, you will loacte for B500 marqued ( XXX ) or J1 you have at least short
the two point with a flat screwdriver and put the upper memory and power on the laptop will holding the screew driver till you see the toshiba screen, if it doen't work just try again. it works 100%
