Toshiba Satellite C50-A Laptop how to remove or reset bios password ?
SOURCE: Toshiba Satellite P25-S5263 Bios reset
remove the cmos battery from the motherboard for 30 seconds.It works i just did it on the a105-s4547 model
SOURCE: toshiba satellite pro 6100 bios reset?
The Password can be removed via the printer port
What you need is a password removal tool, It removes the Bios and start-up passwords.
It costs about £5.00. Easy to build but it costs more to put the kit together.
I think you were quite hard on the assistance.
People here are just trying to help. At least appreciate that!
SOURCE: BIOS Resetting...
Please open this link this will help you
http://www.thenetworkadministrator.com/biospasswords.htm
And dont forget to rate FIXYA if it didnt help please reply but dont rate any rating
Thanks
Regards
SOURCE: how to remove bios password for Toshiba Satellite A200
If you know the current password, use it to enter BIOS SETUP.
Then, type a "blank" ("space-bar") as the "new" password.
If you don't know the current password, you're stuck;
this is a "security" feature to prevent a stolen laptop from being used by the thief.
SOURCE: toshiba m65-s9092 satellite laptop locked with bios password
Remove the battery, and the memory cover (1 screw), and the memory module(s). Under the bottom memory module, there is a white sticker (the bigger sticker)... remove that, and there is a small copper lead labeled J2 that looks like two E's mated with each other, you need to short the E's to each other for about 30 seconds with something metal. Put at least one memory module back in, and the battery, and try booting. If it still has a password, try again for a little longer, or press a little harder with the metal object to ensure you are making a connection.
Reset the CMOS
· The CMOS is, in basic terms, the part of the motherboard that stores the BIOS settings. To remove the BIOS password from your Toshiba laptop, your best option is to forcibly clear the CMOS. Use a Backdoor Password · If resetting the CMOS doesn't work, then your next bet is to try using a backdoor password. A backdoor password is basically a password that manufacturers include with the BIOS so that technicians can access the computers that people send in for repair. An example of a Toshiba backdoor password is, unsurprisingly, "Toshiba." When the BIOS prompts you to enter a password, entering "Toshiba" may allow you to access your PC and clear the old BIOS password. Another option is to hold the left "Shift" key down while booting.
To clear the CMOS, you must remove the battery from your laptop and leave it out for at least 30 minutes to an hour. The way to remove the battery from your Toshiba will largely depend on the model. A common way to remove the battery--particularly with newer models--is to release the battery lock on the bottom of the laptop, while sliding the accompanying tab over to the side. This will pop the battery out from its tray so that you can then pull it out all of the way out.
Before you remove the battery, turn off the laptop and remove the AC adapter. Otherwise, you could end up harming yourself or the laptop components. You must also ground yourself to prevent damaging the laptop with static electricity.
After about a half an hour or more, return the battery back to its tray and lock it into place. Power on the laptop. The computer, ideally, should no longer ask you for a BIOS password.
It's important to keep in mind that resetting the CMOS means that all of your BIOS settings will be reset to factory default. Also, sometimes you may need to leave out the battery for much longer than an hour to reset the password
How to reset a Toshiba Satellite c50 bios password
Same my laptop
