Viking Professional VCBB363SS Stainless Steel Refrigerator Logo
Jacquelyn Zito Posted on Dec 25, 2013
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Light bulb burned out
Left the door ajar and it blew out light bulbs. Everyone says to unplug but the fridge is built in. Do you think if I shut the main breaker it would work? Also it blew out the freezer lights as well even though the fridge door was the only one left open. Thanks
  • 1 more comment
  • Jacquelyn Zito
    Jacquelyn Zito Dec 26, 2013
  • Jacquelyn Zito
  • Jacquelyn Zito
    Hi -- The door's screw at the bottom to make it a 90 or 120 degree angle fell out. My husband screwed it back in and when he did that, the door was beeping that it was open and then the lights burned out. I have a VCSB423SS, by the way. Not what is indicated on this problem. How can the one light bulb I replaced be working and the other 3 brand new bulbs not be working? And how can the freezer lights not work if that door wasn't opened? The ice tray light is still working. Thank you so much!
Gere knutson
Level 3:
  • Viking Master 842 Answers
  • Posted on Dec 26, 2013
Gere knutson
Viking Master
Level 3:
Answers
842
Questions
Helped
218526
Points
2087
Did you have a hinge kit recently replaced? If so call them back they missed something. If not, look into the light circuit a if it goes to ground this light issue would happen. Most of these issues I found in the upper section behind the upper grills. I hope this helps
I’m happy to help further over the phone at https://www.6ya.com/expert/gere_bf68e6055dd61249
2 Related Answers
Anonymous
  • 42 Answers
  • Posted on Dec 21, 2008
SOURCE: Fridge light not shutting down, alarm on, temperature heating up
you do have a switch at the top door hinge . make the phillip screw are tight at the top of the door . if they are loose the door will not align in order make contact with that switch. or you may have a faulty light switch
Anonymous
  • 43501 Answers
  • Posted on Jun 01, 2010
SOURCE: Refrigerator not cooling
There are a few reasons why the refrigerator part will not cool...here are a couple of tips that will help you to figure out why the refrigerantor is not cooling...
Refrigerator2_bing.gif not Cooling or Fridge not Cooling
http://www.fixya.com/support/r3662945-refrigerator_not_cooling_or_fridge_not
How to Defrost Refrigerator Defrost Timer Problem
http://www.fixya.com/support/r3771673-defrost_refrigerator_defrost_timer
heatman101
Door ajar warning light/interior light won't come on
Good Afternoon bibliophilel, based on the symptoms you are describing, may I suggest resetting the refrigerator. This can be done by either unplugging it or flipping the household circuit breaker off. Wait roughly ten minutes and then turn the unit back on. If the issue persists, then more than likely the light socket and/or the door switch that triggers the bulb and alarm are faulty. In this regard, I would suggest contacting an Authorized Service Technician that will be able to assist you in the exact diagnosis of the appliance and repair.
I have a Whirlpool side by side fridge freezer with ice maker and water dispenser which is about 3 years old. Model number I think is WSC5533. Recently I had an interior lamp bulb blow in the fridge which...
HI,
You may have a failing door switch which is causing this problem, if you remove the bulb and close the door, the the red light out? If so, its possible you bulb is fine, you door switch has failed.
I hope this helps
I have a Kenmore Elite stainless steel three door refrigeator I bought it oct 07 at sears. This am I got up opened the refrigerator door and it was hot inside I think maybe the door was ajar over nite can...
Do you recall if the door opened easier than normal that morning? its possible, but not likely, that the door was open, but its kind of hard to make those frech doors stay open even partially. you may have a bad light switch not shutting light off. is any of the plastic around the light bulb melted?
I have to think its something with the light bulb, since you say it was hot inside. thats a far cry from the not really cold i normally hear from my customers.
some french door fridges use a sort of finger mechanism located at the top outer corner of doors, if this breaks, the doors might not close easily by themselves, or worse, not stay open. without personal inspection, i cant give definitive answer
Light bulb blew out. Put in replacement bulb, which will not turn on in frig, but will work in a lamp. Is there a fuse top replace or a circuit breaker to reset?
No there is not a fuse I am sorry to say, you are probably dealing with a broken wire or shorted socket. If you are brave you can unplug the fridge and remove the screws holding the control box(plastic casing the light is set into) and check the 2 wires going to the light for breaks or burns. Also make sure your door switch is opening and closing to allow the light to come on.
1helpful
Light is off in fridge and the bulb is NOT burned out
first unplug the machine then:
check the lamp scoket for flattened metal bars
if they are not touching the bulb pull them up to contact the side and, bottom of the lamp base replace the bulb and plug the machine in then:if that didn't work; if you can substitute another new identical bulb then: check again next check for a broken door switch
2helpful
2answers
Power and no lites in refrig/freezer; beeping
depending on age of unit, the problem may lie in the light bulb,well the door closing anyway, the newer unit s actuall will shut down all interior lights, in the evnet that teh door is left open for more then 2-3 min, so its possible that a light switch is not being activated so the uit thinks the door is open and has shut down the rest of lights, cooling however does continue normally.
4answers
Won't start, just beeps - sounds like door switch problem others have had
The three short beeps could be part of the fault code. Check the owners manual and there are diagnostic sheets on the inside of the machine. I cannot find this fault code in my data base. What is the Model and Serial Number of your Dryer. Check the Power inside the machine at the power cord power connections. You should have 120V from both power terminals to the common terminal. There should be 240 Volts across the main power terminal. Another quest replaced the power cord. Hope to hear some good news soon.
InMrFixIt.
2answers
Fridge bulb burns out in fridge side
check to see if the light is turning off when you close the refrig door. its possible the door is out of adjustment and is not hitting the light switch properly when the door closes
Top Viking Refrigerators Experts
Jay Finke
Jay Finke
Jose Ramirez
john h
Are you a Viking Refrigerator Expert? Answer questions, earn points and help others
