Hi I bought 4gb sdhc card and hp 375 won't take it any way to solving it
SOURCE: WHEN MY SDHC CARD IS
check your card in card reader it is working properly or not.then ps let me know if u need further assistance.
SOURCE: memory card error for 4GB SDHC card on HP Photosmart printer 2710
Well SD max is 2gb, so you can get 2gb if you want.
SDHC max is 32gb. If you are not on a budget, try upgrading your printer to a newer model.
SDHC is coming out with even newer models, now with a class 10 (10mb read/write speed - but very costly).
However, if it doesn't matter to you, might as well just stick with the same printer, since SD cards are coming down in price. Just make sure you get 2gb cards with a good class speed.
SOURCE: I continue to get this error message on my HP A612.
first check the card to make sure it isn't write protected, if it isn't write protected, put the card into a camera and the camera should fix it
REF:
http://h10032.www1.hp.com/ctg/Manual/c00701123.pdf
SOURCE: When I insert a SDHC memory card in printer,I get
Your printer was designed to use SD cards with a maximum 2GB capacity. It was not designed to be compatible with SDHC cards and cannot read them.
SDHC cards are a later development and will fit into the same slots, but are technically different. As the difference is due to hardware incompatibility, there is no way to update your printer to accept the later standard.
