Panasonic cordless handsets. 6.0 DECT Handsets frequently cut out when I try to answer. Then they come on normally or all of the sudden the full batteries need to be charged or the LCD actually goes upside down temporarily?! I purchased these used on ebay-trying to decide if I should return or if it can be fixed with new batteries?
SOURCE: GE MODEL 28112 DECT 6.0 CORDLESS PHONE
I contacted GE today and they told me how to get the caller ID to work on the additional handsets. You must follow these steps in the exact order given.
#1 - unplug the base phone
#2 - unplug the telephone line from the base phone
#3 - remove the battery packs from the phones
#4 - wait 10 minutes.
reverse the order when assembling. Put battery packs in phones, put the telephone line back in the base phone and lastly plug all phones back in. It takes about another 10 minutes after that before all phones start recognizing caller ID but it now works fine.
SOURCE: I have a Panasonic KX-TG6051CM
I had the same problem, and it seems that the battery charging circuit in the handset had locked up, constantly charging the battery until it overheated. I was able to reset the circuit in my handset by completely draining the battery. Here is the procedure:
1. Remove the handset from the charging cradle, and leave it on for a few days until the battery runs out, and the handset finally turns off. At his point, the battery will be very low, BUT NOT COMPLETELY DRAINED.
2. Next, you must manually drain the charge remaining in the battery by shorting out the two contacts on it. Shorting won't damage the battery, since it is holding very little charge at this point. An easy way to physically do this is to remove the battery, and place a piece of thin wire across the the two contacts of the HANDSET. I am referring to the contacts inside the handset that connect to the battery, NOT the contacts on the bottom outside that connect the handset to the charging cradle. Next, put the battery back in, sandwiching the wire between the battery's contacts and those inside the handset. This will hold the wire in place. DO NOT PUT THE HANDSET BACK INTO THE CHARGER, WITH THE BATTERY SHORTED OUT.
3. Wait about 30 minutes for the battery to completely die. Remove the jumper wire, and but the handset back into the charger.
4. If the battery was fully discharged , you will get a message on the handset telling you that you should let it will charge for 7 hours. If you do not get this message, then either the battery was not fully discharged, or your problem is different from mine. Try the procedure again in Step 3 for another 30 minutes to discharge the battery some more.
5. If you get the "Wait for 7 hours to charge" message on the handset, then leave it in the charging cradle for the 7 hours requested. After that, it should work fine.
Let me know how you make out.
SOURCE: Handset voice very low and LCD display is blank
My 1740 handset volume was also low. As a shot in the dark I changed the speaker and it fixed the problem. I got a new speaker from www.panasonic.com .
SOURCE: Panasonic cordless handsets all say line in use
I had the same problem. Something makes the phone's memory get "stuck." Take the battery out of the phone for a minute and then put it back. Then unplug the phone and plug in again. You need to do this with all extensions. The problem goes away.
