HP Photosmart C7280 Laser Printer Logo
Posted on May 14, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How to scan a document to computer
The scan menu doesn't seem to give one the opportunity to scan to my computer desk top.
Ramel Mayormita
Level 2:
Sergeant:
  • Expert 240 Answers
  • Posted on May 14, 2009
Ramel  Mayormita
Expert
Level 2:
Sergeant:
Answers
240
Questions
Helped
65537
Points
754
Try to scan a document to computer from the printer panel ..
Model RX595. how can I open the scanner?
First of all make sure you have connected your printer to your computer correctly. Then you click your printer icon either from your desk top or from control panel. You will get a page with various selection. If you want a document to scan, you click the document to file and you will see at right hand bottom page scan. You click on scan and it will scan. Make sure your printer in on and the printer cable is connected at USB port or the correct printer port. Some people connect it to Ethernet cable port!
Once it finished scanning you can either add page or save it with whatever name you wish to give.
1helpful
Enlarge photo from a scanned photo?
Hi, What printer are you using? Do you have a user manual for it?
I use an HP Photosmart Pro B8330 printer which I have set up to print in a number of qualities and formats. They appear as four separate HP printers on my computer in addition to the other printers shown there in the drop down menu (interestingly the Bolt PDF printer shown is a most useful free down loadable one from http://www.nchsoftware.com/pdfprinter/ it allows me to print documents and pictures into PDF format).
When I select a picture on my desk top by right clicking it, then select print, I get a window as shown in the attached pictures with a drop down menu which allows me to select the printer I wish to use. Having selected the printer with the format I wish to use I am given quite a number of printing options from full page to 35 pictures per sheet. Most printers come with appropriate software which should give you similar options.
How do I scan and save to my desk top
Kathryn,
1- scan your document with your software printer
2- save it on your desktop pc
3 - right click on the document scanned, and choose ; send to the recipient
Where is the option to scan to a word document?
Ones you on the printer and system, then on the desk top you can find HP solution.
Open that then you get the options of action
"Scan photo"
"Scan document"
etc
Go to the Scan Document and follow the instructions.
How scan document to desk top Mac
pls. follow this link for it will give you a walkthrough on how to rectify your problem
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c02456650&cc=us&lc=en&dlc=en&product=1141647&tmp_track_link=ot_search
hope this helps
I want to change the desk top picture on my Dell Inspiron Mini . When I right click on the desk top , I do not get the option to personlize. Seems like something is missing. Could you give me some kind of...
Right click on an open spot on the desktop. Select Properties from the drop down menu, select DESKTOP from the tab menu and choose your background from the list
How do I scan a document using the hp psc 1315 and then find it on my computer? I press the scan button and it seems to scan, but then I can't find the newly-scanned document anywhere. There needs to be an...
The scan button is setup to push the scan to an application, if you uninstalled the HP scanning software, it isn't going to go anywhere. If you didn't, it will put it into your documents folder under "My Pictures" in an HP created folder.
That said, you can also go into any application, like Word. then click "Insert > Picture > From Scanner or Camera" and carry the image in directly.
1helpful
Scanning pictures seems sluggish
there probably is but it likely is not called "scan time" or "scan speed". It has to do with the quality of the scan. Lower quality (less resolution, less dpi) gives quicker scan (but like I said, lower quality scan).
1helpful
2answers
I want to save scanned document as a .doc using CanoScan 8400F
Scanners only see millions of dots. Unless it has software to convert a picture into a document, all documents are seen by scanners as pictures made of of millions of dots. Software is available to convert it to a Microsoft Doc format but it is very expensive.
I have a MFC-8500 Printer and I'm trying to scan and save a document but it won't scan it, but it does come up on the computer for me to save but I can't if it doesn't scan it first. Help!
hello sylvia 624
do you have the scan program from brother called paperport on the desk top? well! the best and easiest way is to go to paper port on the cpu and bring up the paper port program and follow the prompts for scanning the document, i know some people scan from the machine , however i prefer to do it this way. brother tech
k24674
Grand Canyon Tech
Grand Canyon Tech
