Trying to install p-touch driver (latest off brothers site - PD24NT0E) on XP Pro SP3 machine. Although the install goes w/o error's I cannot print on the p-touch or set the baud rate - always fails. I have un-installed and re-installed with firewall and virus protection disabled, but no luck. I really need to use the p-touch editor to make some custom labels!!
SOURCE: change cartridge Problem - Brother BRTPT65 P-Touch Model PT-65 Home and Hobby Label Maker Printer
Once you snap in the catridge you have to put the back of the p-touch back on. After that you can feed through the tape by pressing Code Space. If the back of your P-touch is not on it will not advance through.... I learned the hard way :) Hope it helps you all.
SOURCE: Ink will not print
www.ptouchdirect.com/ptouch/umpt65.html
this is a web page with the manual should help
SOURCE: Need user manual
Hi
heres the user manual
http://www.ptouchdirect.com/ptouch/umpt80.html
Thanks,
Ekse
SOURCE: baud rate
Please follow the steps given below to reduce the baud rate on your printer.
1. Turn on the HP all-in-one.
2. From the keypad, press * and # keys simultaneously.
3. Press 1, press 2, and then press 3. Service followed by a number will be displayed on the front panel.
4. Press the right-arrow to select System Configuration.
5. Press Enter on the front panel.
6. Press the right-arrow to select R/W Parameter.
7. Press Enter. Parameter 0 will be displayed on the front panel.
8. Press 1, press 5,press 1 (i.e,151) and then press Enter. The display should read Value followed by a number (example, Value 60).
9. Press 2, press 6, and then press Enter. This will display Parameter 0 on the display.
10. Press 1, press 5,press 3 (i.e,153) and then press Enter. The display should read Value followed by a number (example, Value 60).
11. Press 0, and then press Enter. This will display
12. Press Cancel repeatedly, until the display reads the date and time.
SOURCE: I need to set my
Unfortunately, it is not changeable with this unit. Your best bet is to experiment with the V.34 and error correction settings and hope for the best.
