Prints very light and some lines you cant even see
I take out the cartridges to reveal the print heads within the carriage.
Then connect a syringe with a pipe on it filled with cleaning fluid and force the fluid through each print heads. Please follow link.
http://www.specialistinks.com/unblock-printer-heads.php#
SOURCE: Black Ink Skipping
If you open the printer so the cartridges move to the center and lift the gray handle so you are able to pull the printer head out. Chances are when you do... you will see all the corrosion. Just clean it off and you should be good to go.
SOURCE: Epson CX6600 Skips every other 5th line when printing
Run the print head cleaning routine from the printers driver or control panel. you may have to run it 3 or 4 times to regain all the lines.
SOURCE: white lines on printed photos Epson Stylus NX400
You need to clean the print head on the cartridges , please follow these steps\
# Hold the cartridge upside down, with the bar-code label facing you and take a damp paper towel.
# Use the towel to wipe the printhead of the cartridge on the bottom (where the ink comes out). Wipe the printhead horizontally in one direction only (left to right).
# Continue doing this until it looks clean.
# Then dab the cartridge on the towel to make sure the ink is flowing.
# Next, look inside the printer and locate the carrier that holds ink cartridges. Caution: Make sure the cartridges are not installed at this point.
1. Look for a shiny piece of metal underneath the contacts at the back of the carrier.
2. Take a damp cotton swab (use water only!) and wipe along the bottom of the shiny metal piece. Note: You may need more than one swab.
# Reinstall the cartridges, making sure you snap them correctly into the printer.
SOURCE: Epson R230 printing unwanted lines
The problem is waste ink around head sprayer (at (bottom plate of head). Turn of printer. Move head to center. Put wet tissue (with hot water) at head cleaning mechanic pad. Move head to parking position. wait till 10 minutes. check it. You can repeat 3 times.
SOURCE: Windows 7 is not recognizing me Epson RX595
The following steps may help:
