Most home Microwaves draw about 12-14 amps. You could figure your wattage at about 1680 watts. Calculated by factoring the voltage of most units 120V times the typical amperage draw of 12-14 amps. so wattage is volts times amps or (12-14 X 120) 1440-1680 watts
There should be a sticker or plate mounted on the door jam of the unit that will say what the wattage is. if not, contact the manufacturer with the model number and they'll be able to tell you.
Wattage is based upon voltage & current. I would think that on the 1300W unit, either the voltage or the current is higher than that which is used on the 1200W unit.
Perhaps the magnetron in the 1300W unit is being driven harder. Are the fans the same size?, The magnetron in the 1300W could be running harder and they have a larger fan in it.
In any event, if the part numbers are the same, you should have no trouble using one units parts to fix the other.
