I have a Goldstar Microwave oven in the above model. I need a transformer to use it here and the electrical company selling transformers has asked me the wattage of this model.
According to the original operating manual that I have (p. 12), the power output of the ER-4010 is 500 watts.
Aug 31,2019 Mine doesn't state the waytage either, but I think it is 800 W, although it could be 850 W ..
Most home Microwaves draw about 12-14 amps. You could figure your wattage at about 1680 watts. Calculated by factoring the voltage of most units 120V times the typical amperage draw of 12-14 amps. so wattage is volts times amps or (12-14 X 120) 1440-1680 watts
SOURCE: do you know what the wattage is of the Goldstar MA-685M Microwave Oven?
600 watts, according to the repair manual.
SOURCE: i need know in/out de control board transformer of
$175.00 at www.partselect.com Are you sure it's the transformer?
Please rate solution
Testimonial: "Yes, I'm sure, because the transformer is burning the secundary output voltaje"
SOURCE: I have a goldstar microwave oven mfg during 1988.
I can't find any info on this model probably due to its age, but there should be a data plate or sticker located either (1) on the back, near the cord (2) side (3) inside back or side wall (4) on the door or door jamb of the oven. Failing this, that next step would be to contact Goldstar in the method of your choice from the webpage below:
http://www.goldstarappliances.com/contact-us.html
I hope this helps & good luck!
SOURCE: micro wave not working jen air
The Transformer is part number 56001221. I have run a search for the part and I am coming up with the same results, the pat is discontinued and no longer available.
Sorry
