SOURCE: not reading Hi8 tapes
Fidus, I am not sure where you are located but the camcorder you're trying to use now is a PAL version of Sony's 8mm camcorder. If the tapes you recorded earlier were recorded in D8 (digital 8) or 8mm/Hi8 format NTSC, they will not play correctly in this unit. The NTSC and PAL formats are different and not compatible. Hope this helps you. Joe Weibel customelectronics.org
SOURCE: Hi8 playback problem
your guides have come loose , probably - the digital sound will be next to go because the bottom edge of your tapes are being folded - open the cassette tape lid by pressing the small pin near one hinge and gently lifting the door - if there are any creases ? get the guides aligned ! to protect your library ; ( if there are no creases , try a sony d8 cleaning tape - once ! before getting a repair quote ) ;
SOURCE: motor plays at a very slow speed
capstan belt may be failing. check this by removing lid and touch the capstan flywheel when running. if it is easily stalled/slow to come up to speed and or the belt slipping badly then belt will require replacement.
SOURCE: Hi8 camera tapes
any brand of hi8 or digital8 camcorder will play back those tapes but sony made a tape deck made to record and play back digital8, hi8, and 8mm tape. you can get here http://www.sonystyle.com/webapp/wcs/stores/servlet/SearchCatalog
SOURCE: Playback problems started suddenly
I had the same problem. I fixed it by gently dropping the camcorder on the carpeted floor. I know it sounds silly, but it really works. I've had to do it twice, and it worked both times. I hope it works for you.
