20 Most Recent Panasonic RR-830 Desktop Cassette Transcriber / Recorder Questions & Answers
Hello your unit needs service and is probably need to replace internal power switch you may take advantage of after Christmas 50% Off Service Rates Special it is only from Monday Dec. 26th thru Friday Dec. 30th 2011 only. At http://www.tvps.com/Products/One-Service-Unit-for-AnalogDigital-DesktopPortable-DictationTranscription-Machine__ECS-ADDPS.aspx
Panasonic RR-830... | Answered on Dec 24, 2011
It could be the rewind solenoid is jamed up or there is a switch that comes loose under the tape deck. Either way, it will need to be serviced.
dictationmall
Panasonic RR-830... | Answered on Nov 03, 2011
With the foot pedal connected, you need to push the play button on the unit. Then the pedal will operate.
Panasonic RR-830... | Answered on Aug 26, 2011
Most likely the unit needs new belts. Also possible that a switch has broken. the switched is underthe tape deck on the circuit board.
Panasonic RR-830... | Answered on May 06, 2011
Likely problem could be a faulty pause lock switch
Panasonic RR-830... | Answered on Jan 17, 2011
when you press the power button is there a light indicator or the machine turn on even for a few seconds. if not maybe its the power supply or the power cord.
it could be internal problem
if you want to fix let me know
ecrdn@yahoo.com
Jack
Panasonic RR-830... | Answered on Nov 04, 2010
The buttons on this machine are gated with a mechanical mechanism (under the buttons in the machine -= you can't see it) that acts as a "gate" to control how the buttons behave. This mechanism is probably stuck and needs to be looked at by someone with mechanical inclination - short of calling customer service for service locations. It shouldn't be that expensive to fix. Good luck.
Panasonic RR-830... | Answered on Apr 20, 2010
Most likely the internal belt has broken.
Panasonic RR-830... | Answered on Jun 30, 2009
If the foot pedal is pluged in, press the play button and then you should be able to activate it with the pedal.
Panasonic RR-830... | Answered on Feb 05, 2009
The tapes may have been recorded at 1/2 speed or 1/4 speed so they are not playable on this model.
Panasonic RR-830... | Answered on Jan 15, 2009
The headset you are using is a stereo headset. This unit uses a mono headset. Look at the end of the headset. If there is 2 black rings, it is stereo. You can get a stereo to mono adapter at Radio Shack for about $2.50.
Panasonic RR-830... | Answered on Nov 15, 2008
This is caused be a bad record switch. As a temporary solution, incert a blank tape, push the record switch, then stop. Repeat about 10 times. This may clean the contacts of the record/Play switch but it will probably need to be replaced.
Panasonic RR-830... | Answered on Nov 08, 2008
The headset jack is broken and needs to be replaced.
Call tech support! That's why these people get paid. Sites like this wouldn't need to exist if they did their jobs correctly!
Panasonic RR-830... | Answered on Jul 10, 2008
Hello William, I sent you the link to download the user manual of your SA PT 70
I hope you can solve your concern
Greetings Franco Dosil
Hola William, te envio el link para que descargues el manual de usuario de tu SA PT 70
Espero puedas resolver tu inquietud
Saludos Franco Dosil
http://panasonic.ae/en/manuals/SC-PT75.pdf
Panasonic Audio... | Answered on Jun 14, 2019
Panasonic RR-830 Desktop Cassette Transcriber / Recorder Logo
23 questions posted
Top Panasonic Audio Players & Recorders Experts
 Grubhead
Grubhead
Joaquim Martins
Are you a Panasonic Audio Player and Recorder Expert? Answer questions, earn points and help others
View Most Popular
  • Panasonic Audio Players & Recorders
Most Popular Question
panasonic rr 830
  • Audio Players & Recorders
