Remove the image unit and then remove the drum and clean the drum sensors also might need anew drum. when was the last PM done on the machine Meaning developer and drum cleaning blade and toner collecting roller replaced? If all above was done did that person use a vacuum cleaner to remove the old developer if so the static electricity from the vacuum cleaner may have destroyed the sensor causing the code. NEVER EVER use a vacuum clear when replacing developer
New developer module or new developer material?
Either way, unless you are trained (or experienced) at this task, I would recomend having a qualified service tech perform this task. Mechanically speaking, it's not difficult to remove the module to pour out the old dev. material, however, there are codes that have to be set to run Auto Toner setup afterwards....that's the kicker.
important to know the true copy count drum and fusing last about 80k copies and are expensive so be careful WHO you buy from in chicago call 7734748865
hello gud day. i have 2 toshiba dp 3580,i have no comment on this.its really heavy duty..the copy is very clear and everyday my machine always functioning.no problem at all..easy to maintain .always keep it clean..
