Press "Sleep Timer" on the remote, while "0 Minute" display on screen press both "Display" & "V.Status" @ same time, this should bring up the service menu....
convergence issue. The JVC repair kit called the AV48wp30 - AV65WP30 convergence repair kit is the correct kit for your model and symptom. Its available from www.tvrepairworld.com and the kit contains the parts and the CD with repair instructions.
Convergence needs repair. The AV48WP30 convergence repair kit from www.tvrepairworld.com has the parts and the CD with step by step repair instructions.
The AV48WP30 convergence repair kit from www.tvrepairworld.com should repair that issue. The kit contains the parts and the Cd with detailed instructions.
That sounds like a convergence failure. The AV48WP30 convergence repair kit from www.tvrepairworld.com should solve the issue. The kit contains the components and the CD with instructions.
You can get the JVC AV48WP30 convergence repair kit from www.tvrepairworld.com which should repair that issue. The kit contains the parts and detailed instructions on CD
THE JVC AV48WP30 convergence repair kit from www.tvrepairworld.com usually will fix that issue. The kit contains the parts and the CD with detailed instructions.
you need the convergence repair kit which contains the replacement parts and the detailed instructions on how to do the repair. The JVC AV48WP30 -AV65WP30 convergence repair kit is available at the following link under the JVC repair kit category. The Instructional CDs are very detailed so its a easy repair. http://www.tvrepairworld.com/
you can get alot of different opinions on here but the best i can do is tell you to call a tv repair service to have them come out and repair the tv instead of trying to do it yourself and possibly making it worse than it allready is. with a repairman you get a guaranteee its fixed on here all you get is guesswork and you dont need that
Send them an email and mention that slinteriors asked them to give you a complimentary copy of the IC instructions, and they will . The head techs email is [email protected]
