JVC AV-48WP30 48" Rear Projection Television Logo
Anonymous Posted on Nov 23, 2009
Our TV has, almost what appears to be, a double, colors are shadowing
Sonny Berry
Level 3:
  • JVC Master 8,617 Answers
  • Posted on Nov 23, 2009
Sonny Berry
JVC Master
Level 3:
Answers
8617
Questions
Helped
1721651
Points
23750
You can get the JVC AV48WP30 convergence repair kit from www.tvrepairworld.com which should repair that issue. The kit contains the parts and detailed instructions on CD
Testimonial: "Thanks muck"
I have a severe shadow on the screen in all colors.
Hey there,
Your issue is related to the small chip inside the Tv, I believe they are called the light engine. It is a small plastic frame with what looks like a graduated glass pane in the middle. Over time this begins to show its age and amount of use by casting the shadow to which you refer. For some it appears as yellowing in spots. It is replaceable but should only be done by those with the right skill and tools. Maybe double the cost of the lamp or a little more depending on Brand.
1helpful
It has double images. The words are doubled even, appearing blurry. We are currently playing a DVD "daddy daycare" The words on the car are unreadable because they overlap. At the bottom of...
Ur tv have a problems known as a convergence pictures problems,it is dead.Tv have any colors lines R,G,B mis alignments,have colors shadows pictures or 3D pictures look alike?Yes,than the tv have a dead convergence board to causes these problems.The tv convergence board must have to be repair like replacing 2 STK convergence ICS and some or all of it resistors too.To fixed the tv convergence board to solved the tv convergence pictures problems.The tvs shops will cost u like $300-350 for parts and labors.
I have a RCA Model R52WH74. It hs a double view to it liek the colors has seperated. It also has a wavy red line across the top. It looks like the projector bulbs are out of line. All three bulbs are...
The tv have a problems known as a convergence problems,it is dead.Tv have any colors lines R,G,B mis alignments,have any colors shadows pictures or 3D pictures look alike?Yes,than the tv convergence board it is dead,convergence board must require changes 2 STK convergence ICS and some or all of it resistors too.To fixed the tv convergence board to fixed the tv convergence picture problems.The tvs shops will cost u like $300-350 for parts and labors.
Images show double images like shadows
Ur tv have a problems known as a convergence problems,it dead.Tv have colors lines R,G,B mis alignments,have colors shadows pictures or 3D pictures alike?The tv convergence board have dead 2 STK convergence ICS and some or all of it resistors too.These parts,must be replaced on the tv convergence board to fix the tv convergence board to solved the tv picture convergence problems.Try website like Tvrepairworld.com to buy a whole convergence board for the replacement,might still have it.The DLP tvs AKAI and Samsung tvs used the same convergence board.Or the shop,will cost u like 300-350 for parts and labors.
The picture is "ghosting" or doubled
The tv have a problems known as a convergence problems,it dead.The tv have colors lines R,G,B mis alignment,have colors shadows pictures or 3D pictures look alike.The tv convergence board have dead 2 STK convergence ICS and some or all it resistors too.These parts on the tv convergence board,must be replaced to solved the tv picture convergence problems.The shop,will cost like $300-350 for parts and labors.
We have a blue tint and a shadowing effect that makes it appear to have a double on the screen of the same figure / word(s)
This problems is known as a convergence problems,it dead.The R,G,B colors lines mis alignment,have colors shadows or picture look like 3D pictures.The tv convergence board,it dead.Require,must be changes 2 STK convergence ICS and some or all it resistors to solved tv convergence picture problems.The shop,will cost u $300-350 for parts and labors.
2helpful
I have a hitachi ultravision digital hi-def TV model number 53UDX10B from December 2001. The words in its own menu and from my cable box menu are distorted, as well as some words appearing in commercials,...
The tv problems known as a convergence problems,it dead.The colors lines R,G,B mis alignment,have shadows colors pictures or 3D pictures.The tv convergencce board require changing 2 STK convergence ICS and some or all it resistors are dead.The shop,will cost $300-350 for parts and labors.
2answers
Picture is multi color, double shadows, curved
This is failure of convergence out ICs in TV. Qualified TV tech will replace convergence out ICs or board.
2answers
Hitachi 53UWX10B Projection TV colors not lining up...
This is a convergence issue..both chips need replacement.
Red Shadow on scheen
your tv needs to be align take it to a tech so that the tv can get a convergence adjustment it is call color bleeding.these things when a set gets old this wil cost between 440.00 TO $75.00,in this the comb filter and the screen voltage will be checked.
Top JVC Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
 Grubhead
Grubhead
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
