Computers & Internet Logo
d
dora Posted on Nov 24, 2013
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Power supply serial number for
Please inform me
James Miller
Level 3:
Renaissance:
An user who is expert in 3 categories / brands.
  • IBM Master 2,226 Answers
  • Posted on Dec 07, 2013
James Miller
IBM Master
Level 3:
Renaissance:
Answers
2226
Questions
0
Helped
447573
Points
2985
Take it to a computer sales store they will have it for you.
1helpful
I need an owner's manual for a Generac Power Plus generator. Model #09856-0, Serial #1501916, Series #PWR+5.
Model not found on Generac web site using model number or serial number.
Generac contact information on their web site to request assistance:
https://www.generac.com/service-support/contact-us/online-form
Craftsman mower serial number 1F136k92008. I need info please.
you will have to supply more information
what motor does it have
what are the identifying marks (model numbers ) on the crankcase of the motor
post the statement and the additional information and exactly what information you require again to get a better answer
2answers
Have one --would to know how old it is --serial #--YDGN1015003922
not enough information
if it is a sewing machine , please realize that it is one on hundreds of makes and models and serial numbers are no help unless you supply the rest
post it all again as posts are not linked
How Can I Obtain the Serial Number of a Modular Switch?
Obtaining the Chassis Serial Number · On a standalone switch:
Log in to the switch through Telnet or the console interface, and then run the display elabel backplane command in the user view to view electronic label information. In the command output, the BarCode field indicates the chassis serial number.
<Quidway> display elabel backplane
Info: It is executing, please wait...
[BackPlane_1]
/$[ArchivesInfo Version]
/$ArchivesInfoVersion=3.0
[Board Properties]
BoardType=EH02BAKKBarCode=2102113089P0BB000881
Item=02113089
· In a CSS:
Log in to the master switch through Telnet or the console interface, and then run the display elabel backplane chassischassis-id command (chassis-id specifies the CSS ID of a member chassis) in the user view to view electronic label information. In the command output, the BarCode field indicates the serial number of the specified chassis.
<Quidway> display elabel backplane chassis ?
INTEGER<1-2> Chassis ID
<Quidway> display elabel backplane chassis 2
[BackPlane_2]
[Board Properties]
Item=02113549
NOTE:
The command syntax may differ in different software versions. You can enter a question mark (?) to obtain help information about the command and set the chassis ID according to the help information.
Obtaining the Serial Number of a Card Log in to the master switch through Telnet or the console interface, and then run the display elabel command in the user view and specify a slot ID according to help information to view the electronic label of a card. In the command output, the BarCode field indicates the serial number of the card.
<Quidway> display elabel ?
<1-1> The present chassis
backplane Backplane
brief Display information briefly
<Quidway> display elabel 1/?
<4,6-8> <CMU1>
<FAN1-FAN2> <PWR1-PWR2>
<Quidway> display elabel 1/6 brief
[Slot_6]
/$[Board Integration Version]
/$BoardIntegrationVersion=3.0
[Main_Board]
[Board Properties]
BoardType=ET1D2S08SX1EBarCode=020LVF6TBB000043
Item=03020LVF
NOTE:
The command syntax may differ in different software versions. You can enter a question mark (?) to obtain help information about the command and set the slot ID according to the help information.
Obtaining the Serial Number of a Power Module Log in to the master switch through Telnet or the console interface, and then run the display elabel command in the user view and specify a slot ID according to help information to view the electronic label of a power module. In the command output, the SN field indicates the serial number of the power module.
backplane Backplane
<5,8,13,16> <CMU1>
<FAN1-FAN5> <PWR1-PWR4>
<Quidway> display elabel 1/PWR1
[Slot_21]
[Main_Board]
DATE=13_02_08 SN=A664A0212080086V0.9A
NOTE:
Obtaining the Serial Number of a Fan Module Log in to the master switch through Telnet or the console interface, and then run the display elabel command in the user view and specify a slot ID according to help information to view the electronic label of a fan module. In the command output, the BarCode field indicates the serial number of the fan module.
backplane Backplane
<5,8,13,16> <CMU1>
<Quidway> display elabel 1/FAN2
[Slot_18]
[Main_Board]
[Board Properties]
BoardType=LE02FCMC BarCode=2103010JTF0123456789
Item=02120995
NOTE:
2answers
Code for dvd player
You will need to remove radio and supply the serial code.
And model number please
Lifestep 5500
Check your power supply output voltage for 12 volts DC. This link will take you to our Website for more information on your model. Please have your serial number ready.
LifeFitness Parts for LS5500 Stairclimbers SPORTSMITH net
There are two numbers on my PowerMust Office 650. which is the serial number I need for software installation thanks for helping me
Well, with only 2 of them, i would try using first the first one, and, if it is the wrong one, then another one. I guess the installation program will inform you in case of invalid serial number and won't exterminate you and your pets, so it is worth trying :)
2answers
My stereo needs code
Please post up the exact make and model of the stereo as the codes are all different for different models. You will also need to supply the serial number of the radio and be aware that not all radios can be decoded by this method from the serial alone.
Once you have supplied the information we can see if we can help.
IBM's power supply Serial number?
I don't know about a command but there is software out there for finding serial numbers or you could do it the old fashion way (if you feel comfortable doing it) and open up the computer and look at the sticker on the power supply. (unless it has worn away or been removed)
Top IBM Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
ExpressFiX
ExpressFiX
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
