Amana gas oven, model # ACF3325AS. Electric starter element for oven does not appear to be functioning. Broiler element works fine, as do stove-top burners. Can anyone give me a part number for the oven element?
I believe there is a thermal fuse (also called a TCO or Thermal Cut-Out) located either on the back of the oven, or between the top of the oven and the cooktop that has opened up. Did this happen after running a self-clean cycle?
F2/F3 Error indicates
a loose/broken wire on the oven temp sensor or the oven temp. sensor itself is
bad and should be replaced. To solve this issue test the oven temp. sensor, it
should read between 1080-1120 ohms, if the rating is more then that and the door
appears to be closing fine then it is the control board that is bad and should
be replaced. Hope this helps...please post back for further assistance.
Daniel
I have seen an oven with an electric Broiler element and a lower gas burner but not one with electric top elements and gas below.
SO Im fairly confident your total electric on this appliance. You will have to check the element and if its ok the voltage to the element. If it has a timer the timer could be keeping it off. check the settings on the timer and see if it will click when advanced. Wait a few min then the oven heat up after a few minutes.
canoyu physically inspect teh element for damage, perhaps its broken. or as wireleadingto the rearof elemnt has buntoff. you can check , but turn offpower first, the wires are always live
