You need a special foot for free motion quilting--it is slightly shorter in height than a regular presser foot, which essentially provides space between the presser foot and the needle plate to manually move the fabric. Sometimes machines came with a standard darning foot accessory. Your Pfaff dealer probably has at least one style in stock. But there are other specialty feet you can probably use, ie Big Foot, clear free motion foot, C-shaped, oval, etc. You can also purchase a shank adapter (verify it is the correct shank for your machine) and use it with a kit of snap-on presser feet so you can have a variety of presser feet for different functions.
like you are on your feet a lot and it hurts so much it feels like it give in? soak in apple cider vinegar and you could probably buy a foot massager in dept.stores
This machine uses 'New style' snap on feet. The reason it is 'new' is because old style Bernina feet are the complete foot, whereas new style you just 'snap on' the foot base.
Ebay is the best place to find original Bernina feet at very reasonable prices. I recently purchased a solid steel 'old style' foot from UK for U.S. $28.
When purchasing zipper feet, decide if you want regular zipper foot or invisible zipper foot. Often it is cheaper to order both at the same time, due to S&H fees.
There will be several zipper feet available at any of the sewing machine stores. You can either take the broken foot with you (or another foot for the machine) or note the shank length and the bar length on the foot. I believe the White uses a low shank foot. In that case, you would get a foot that is designed as a low shank foot (assuming the bar isn't narrower than your current foot), and it will work.
The common Foot styles are low, high and slant.
I hope this helps.
Cindy Wells (you can also order sewing machine feet online but you need to know the style of how the foot connects to the machine. The easiest way to do that is to compare it to similar feet in a local store. Most of the online vendors will list the machine brands that are compatible with a given foot. However, I know that Husqvarna low shank feet have changed width over the past 30 years and thus not all of the feet from a new machine are mutually compatible with those for an older machine. So I wouldn't guarantee the match without seeing the feet side by side.)
Any snap on foot will fit, at least that is what it looks like in your manual. (I looked it up for free at www.singerco.com, under customer support, instruction manuals to download.) You can order from Singer direct or go to www.sewingpartsonline.com search under presser feet and order any one you want under snap on presser feet. They run approx. $14.95 each
its the P foot, which is all clear, and attaches directly to the shank after you unscrew the whole metal foot ( not just on the clip like the other feet) and you screw it into position and it doesn't touch the material
If your SU is an Air Electronic model i.e. 80's model, Elna didn't make a walking foot to fit. However, if you've got a walking foot that is the same height from sole plate to the screw fitting as a standard Elna foot then you could give it a try. The walking foot connects to the presser bar with a screw but the needle bar also needs to hook into a secondary lever on the side of the walking foot to make the foot actually move. Probably sounds very confusing . Check the movement of the foot manually by hand turning the fly wheel to see how it works before you actually use with the motor to minimise any problems if the foot doesn't fit.
Also you'll probably only be able to do straight stitch with this foot due to the clearance around the needle plate.
