Question about Kenmore 15343
Feeder feet under presser foot clicked down not able to get back
Feeder feet under presser foot clicked down not sure how to get them raised up again to start feeding fabric throught again
Posted by mhigginson on
Jann Schott
    Problem Solver:
  • 14 Answers
The switch for the FEED DOGS is on the left side of the machine.
Posted on Mar 19, 2009
I don't know how to use the darning on my bernina 950. Can you advise
You need to use a darning presser foot--there are several designs of darning feet made by Bernina or generic brands (be sure the generic model has the appropriate attachment for your particular Bernina). You can find metal or plastic, clear or solid foot, open or closed toe, spring-loaded hopper or not, etc. Drop the feed dogs. If it is thinner fabric (lighter weight than denim), it sometimes helps to put the fabric in an embroidery hoop (upside down with the fabric next to the needle plate). If the hole is small, you can use the little hoop that should have been included in your Bernina accessory kit. Then you manually move the fabric back & forth, up & down under the presser foot while stitching.
12 BERNINA presser feet Darning foot 9
How to Use the Big Foot Darning Quilting Embroidery
Choose Your Darning Foot Quilting Foot and Learn to Machine Quilt
Aug 08, 2017 | Bernina Sewing Machines
I need instuctions on using different presser foot for ja nome schoolmate
Please add a comment with the specific model of Janome Schoolmate sewing machine.
Fpr the Janome Schoolmate S-3015, make sure that the needle is fully up and raise the presser foot. Then press the red button on the back of the presser foot holder to have that foot drop off. Set the pressure dial to 3 before attaching the new presser foot. For snap-on feet, align the pin of the presser foot (the horizontal bar in the middle of the foot) under the presser foot holder. Lower the presser foot holder (using the presser foot height lever) until it locks onto the foot.
For the zipper foot, you need to fit the rear pin on the foot into groove at the back of the presser foot holder. Then lower the presser foot holder onto the zipper foot.
These are shown on page 11 (14 of the PDF) of the manual. You can download the manual here: http://janome.com/en/machines/sewing/schoolmate-s-3015/ . The direct link to the manual is http://janome.com/siteassets/support/manuals/school-models/schoolmate3015.pdf .
For the S-7330, you need to again raise the needle and the presser foot. Press the lever towards (it moves slightly up, not down) the presser foot holder. Then line up the pin on the foot under the presser foot holder and lower the presser foot holder onto the foot so that it locks. This is also in that sewing machine's manual, here: http://janome.com/siteassets/support/manuals/school-models/inst-book-s-7330esf.pdf . See page 14 (18 of the PDF).
I hope this helps.
Dec 21, 2016 | Sewing Machines
Can the presser foot be raised slightly on pfaff tiptronic 2030 to facilitate free motion quilting? There is not enough clearance with feed dogs down to freely move material to quilt. Thank you.
You need a special foot for free motion quilting--it is slightly shorter in height than a regular presser foot, which essentially provides space between the presser foot and the needle plate to manually move the fabric. Sometimes machines came with a standard darning foot accessory. Your Pfaff dealer probably has at least one style in stock. But there are other specialty feet you can probably use, ie Big Foot, clear free motion foot, C-shaped, oval, etc. You can also purchase a shank adapter (verify it is the correct shank for your machine) and use it with a kit of snap-on presser feet so you can have a variety of presser feet for different functions.
Pfaff Presser Feet
Pfaff Big Foot Free Motion Quilting Foot
Pfaff Free Motion Guide Presser Foot
Pfaff Free Motion Open Toe Quilting Foot
http://www.sewingpartsonline.com/snap-on-sewing-machine-presser-feet.aspx
May 07, 2016 | PfaFF Sewing Machines
How to attach free motion foot
Most free motion feet attach like the other feet.
It is creating "thread nesting" also called birdnesting. Could be several things:
1) make sure before you thread the upper thread, RAISE the presser foot so the thread will seat properly in the tension disks
2) drop your feed dogs before you begin to free motion
3) your free motion quilt foot, when lowered, should not rest on the fabric. (Be sure you are lowering your presser foot when you want to stitch!) You should be able to move the quilt sandwich easily under the presser foot. If the foot applies any pressure to the fabric, you may need to release the presser foot pressure (consult your manual). Or you are using the incorrect presser foot for your machine.
4) If none of the above, you need to tighten the upper tension AND
try this method before beginning to free motion stitch:
How and Why to Bring up the Bobbin Thread
Aug 09, 2015 | Sewing Machines
Pfaff Clasic 2025 and when I start to sew I get a stitch and then it just sets there. the needle just goes up and down in the same stitch and doesn't move forward.
check the feeder feet with out material under the presser foot see if they are up or down and moving or not . some I do know the feed feet are retractable .
May 06, 2015 | PfaFF Sewing Machines
Added top feeder foot and material will not feed through. Do i need a diffevent presser foot, than the normal one, to use it correctly?
check the feed direction for the bottom section
check that the top foot is actually coming down onto the bottom foot
adjust if not or is the foot the correct one
Apr 26, 2015 | Sewing Machines
No knob to adjust presser foot pressure. Space between feed dogs & presser foot is too tight to pull a piece of fabric out with foot down. Diagonal seams get pushed out.
You should not be able to pull fabric from the machine when the presser foot is down. The presser foot should always be raised before removing the fabric.
Are you trying to darn or quilt something without the feed dogs activated? If so, there are special presser feet for that purpose that are shorter in height (ie darning foot) which allow more space between the presser foot and the stitch plate so the fabric can be moved freely.
Apr 17, 2015 | Janome Sewing Machines
The presser foot won't go down.
Yes indeed, it is possible--sounds to me like a screw worked itself loose. However, I would purchase the service manual for your machine. As a bonus, it tells you how to make all kinds of useful adjustments.
Go to Sewing Parts Online and do a search under Singer Service Manuals; if they don't have it in stock, call or email them and they will be happy to order it for you. Generally takes two weeks to get it in stock.
Apr 10, 2015 | Singer 20u Sewing Machine
Threading a needle
1. Turn handwheel toward you 2. Raise presser foot up 3. Pull thread from spool and pull taut under each tension disk. It's important to "feel" the "click" if you are new to threading machine 4.Make sure after all tension disks threaded that you put thread behind the slot in back of your needle. It's a little groove to hold thread securely. 5. Pull thread toward you 6. Thread needle eye front to back 7. Pick up thread under gently pull taut in front of you 8. Lower presser foot and turn handwheel toward you. A loop will form under the needle where needle thread has picked up the bobbin thread. Carefully take both threads that have made a single loop and pull toward you 9. Put threads under presser foot just lift put threads under and pull 5 -6 inches thread BACK and UNDER that presser foot Done! Hope this helps, my friend! Jimmy
Mar 30, 2012 | Sewing Machines
How do I move the presser foot on a Husqvarna Viking Emerald 116 sewing machine?
Not sure what exactly you need to know. Are you trying to lift the presser foot or change the presser foot to another one? If it is lifting, there will be a lever of some kind behind the machine. On one of my Husqvarna machines it was a big flat "paddle" shaped lever, not sure what shape it is on the Emerald machines. Lift the lever from the bottom upwards and outwards. Most Husqvarna machines have clip on-and-off feet. You just gently pull forwards on the foot (while the presser foot is raised) to remove it, then push the new one on making sure the small bar part of the presser foot goes into the clip on the presser foot ankle.
Jun 16, 2010 | Husqvarna Viking 1
Sewing Machines Logo
387 people viewed this question
Top Kenmore Sewing Machines Experts
Irene Tulloch
Are you a Kenmore Sewing Machine Expert? Answer questions, earn points and help others
