Looks like 3D picture without the glasses
SOURCE: 3d look on mitsubishi ws-55511
Hi bluemags,
It is true that you should use a higher power I.C., I do that all the
time. However, the one to use is the STK392-120. This one is rated at 5
Amps unlike the STK392-110, 150, which are both rated at 3 Amps. I have
not checked the data sheet on the 180. They are all OEM, since Sanyo
designed them all. Beware of generic knockoffs not made by Sanyo. The
generic I.C.s do not have the quality as the Sanyo originals.
Best Regards,
MyTvGuy
SOURCE: double vision
convergence fail. try resoldering the 2 convergence ICs in the middle baord located on the large heatsink. this might fix unless the problem has gone it course
SOURCE: error code 22 on a Mitsubishi WS-55907 55'' HDTV
your set is the V17 series so a code 22 means short protect. Which means the TV has a short circuit condition and is shutting down to prevent further damage. You can get a manual for the V17 sereis at the following link for 15.99 and they will provide free unlimited support to help you with the diagnosis and locating parts. Your set is coverd in the V17 sereis service manual under the mitsubishi section. Here is the link in case youd like the service manual and free support.
http://servicemanuals.vstore.ca/
SOURCE: Mitsubishi WS-65611
My mitsubishi 65611 is about 4 years old - I am getting a green overlay color on the screen can you advise what this might be?
SOURCE: Mitsubishi WS-55807 parts in a VS-60603?
I own a Mitsubishi WS-55807 55 in. for parts if you are interested. Please contact me back if interested. 727-773-8208 Nicole
